Air Cleaner Temperature Sensor
Old May 25, 2020 | 06:36 AM
1989IROCTPI's Avatar
Car: 1989 IROC-Z
Transmission: Automatic
Hi,
I have a 1984 Pontiac Firedbird with 4 barrel carburetor. It is 100% stock. after some troubleshooting, I noticed that the THERMAC door is closing when i start the car cold (which is normal) but never opening after it warms up. The thermac door moves freely and the hoses from the thermac to the air cleaner temperature sensor are not clogged so my guess is that little temperature sensor in the air cleaner is at fault. also, If i disconnect the hose at the thmermac fitting the door will open. Does anyone know how this air cleaner temp sensor works? should I spray it with carb cleaner ? it does not look damaged in anyway. I did not see a place where you could buy a new one.
Old May 25, 2020 | 08:00 AM
Manic Z's Avatar
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
Re: Air Cleaner Temperature Sensor
I noticed when my car was stock, that my air cleaner was the same way. Would take forever to open. I think it's just the stock setting.
You can actually adjust it. There is a screw protected by the rubber/plastic. I believe. If you cut it so you can flip it up, you can get access to it. That's what I did.
Old May 25, 2020 | 08:45 AM
gt4373's Avatar
Transmission: 5-Speed Manual
ACDelco Has Them.
Old May 25, 2020 | 09:19 AM
Manic Z's Avatar
If you decide to open yours up, the screw is under the top blue protector:
I can't remember if you turn it clockwise or counterclockwise.
Cut the blue protector on its 'hinges' to be able to flip it open.
Old May 25, 2020 | 09:39 AM
Car: 1989 IROC-Z
Great. OK thank you for the help.
trafalger
Carburetors
Jan 26, 2025 07:47 PM
ZentaiGuy
Jun 30, 2014 11:53 AM
Lo3 maniac
Sep 15, 2012 08:25 AM
mgilorma
May 15, 2012 04:13 PM
The Beast
Jun 28, 2003 01:27 PM
