Kickdown cable
Kickdown cable
Now this might not be the exact place for this question to be, but it has to do with a new carb I bought so I figured I’d ask it here. I have a 1986 Pontiac Firebird base model with a 305 V8 in it. Recently I decided to replace the intake manifold and carb. The intake manifold was simple enough, but I ran into issues with the carb. I bought an Edelbrock AVS2 series carb, and it bolted in fine, the issue is with the throttle linkage and kickdown linkage. They just don’t line up properly. We found a linkage kit that could potentially solve the throttle linkage problem, but can’t find one for the transmission kickdown. So my question is: is the kickdown even needed? It’s a manual transmission car, so why would a manual transmission vehicle need a cable that automatically changes gears? I’ve never had my gears shift automatically, so what is it even there for? Do I need to hook this back up, or can I just leave it/remove it and continue on with just the throttle issue? Any advice here would be great. And also if anyone knows exactly what throttle linkage kit I would need, that would be helpful as well, because right now I’m just guessing and checking. Thanks!
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Kickdown cable
I think you answered your own question. A manual transmission does not use a TV cable or kickdown linkage...
Re: Kickdown cable
It's possible your car was originally equipped with an automatic trans, and a previous owner swapped to a manual and was too lazy to remove the rest of the unrelated components.
Can you post some pics?...
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: Kickdown cable
SaiyajinXero
Dec 14, 2006 12:51 PM
