Sneaky Leak
Old Oct 27, 2021 | 03:49 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Sneaky Leak
I've inspected the Holley 4160 closely on car. The fuel levels are set correctly. No leaks from the bowls or the bowl screws. Nothing from the accelerator pump or fuel line. I thought perhaps the throttle shaft but it appears to sit below where the fuel is most obvious. The leak will dampen the carb-to-manifold gasket a bit at all four corners. Any suggestions?
BTW, while I've rebuilt the carb several times, I've never replaced the throttle body gasket.
JamesC
89RsPower!
Carburetors
Oct 15, 2008 02:28 PM
88 350 tpi formula
Alternative Port EFI Intakes
Oct 10, 2006 03:48 PM
Shake Zula
Carburetors
May 24, 2006 10:29 PM
zee28
Carburetors
Oct 4, 2000 02:30 PM
