How can i get better gas mileage with my carb?
Old Jan 21, 2002 | 06:51 PM
Supercharged84Z's Avatar
Car: 1984 Camaro Z28
Engine: 350 CID
Transmission: Beefed up 700R4
hey guys, i want my car to be powerful, but efficient at the same time. my question is how can i get better gas mileage with my carb???
thanks,
-dave-
Old Jan 22, 2002 | 01:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The exhaust will help, but can also have a negative effect on the economy side.
The basics are: 1) Engine in good tune (ignition fresh, timing set properly) - upgraded coil and module may also help; 2) Properly adjusted choke and clean air filter element; 3) An egg between your right foot and the accelerator - I've seen as much as 4 mpg difference between tankfuls when I did "on-ramp test runs" and when I don't. Keeping the secondaries closed will make a huge difference.
The beauty of the CC carb closed-loop system is that it sips as little gas as possible for the conditions at any given time. Keeping it in good shape is one of the best things you can do for economy.
Beyond that, synthetic lubricants (engine oil, tranny fluid, gear lube), and keeping the tires properly inflated will help both power and economy. Head work (port clean-up, chamber polishing) to improve fuel/air mixing and flow will improve power, but not so much economy (especially from a cost/benefit perspective). A cam change will definately improve the power side, but economy - probably not.
Infested
May 22, 2018 11:56 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
FreeSpirit
Aug 29, 2015 05:47 PM
InfinityShade
Aug 22, 2015 08:00 PM
