87 camaro EFI swap to carb cable routing???
Old Sep 21, 2023 | 01:11 PM
Chaddyboy's Avatar
Just wondering if anyone has a way to install the throttle cable and tranny cable to a edelbrock carb.As stated it was tpi efi now carb so need some thoughts on running the appropriate cable ...Is there a kit to buy ect.
Old Sep 22, 2023 | 06:18 AM
Sharp38's Avatar
Car: 1938 Chevrolet
Engine: ZZ 502
Transmission: 4L60
Axle/Gears: Ford 9 3:70
Re: 76 camaro EFI swap to carb cable routing???
Edlebrock part 8026. Summit Racing and others.
Old Sep 22, 2023 | 07:56 AM
Chaddyboy's Avatar
sorry typo its a 87 not 76 not sure if that makes a diff
Old Sep 22, 2023 | 08:06 AM
Sharp38's Avatar
Car: 1938 Chevrolet
Engine: ZZ 502
Transmission: 4L60
Re: 87 camaro EFI swap to carb cable routing???
I don't know what you have on the engine from the EFI that will transfer over. My EFI had the cable stops and throttle body brackets built in. I suspect you need a cable stop bracket that you need to bolt to your intake manifold that will be the "fixed" stop for the accelerator cable and the Transmission TV cable. Something like Edlebrock 8031. You probably also have to get the Edlebrock 8026 that bolts to the throttle bracket on the carb for the Transmission TV Cable.
Don
Old Sep 24, 2023 | 07:30 AM
Chaddyboy's Avatar
Don
Hey thanks for your imput.Im using an edelbrock carb so i suspect from what i read i will need new throttle cable and tranny as there to long.Also seems a variety of brackets suggest would work .Looks like Amazon has a specter bracket.However I like your suggestion.Ps the beast runs good now.
Old Sep 24, 2023 | 07:52 AM
Sharp38's Avatar
Car: 1938 Chevrolet
Engine: ZZ 502
Transmission: 4L60
I have been able to shorten the cables by pulling out the inside and cutting the outside with a cutoff wheel But, new cables are always nice and look better.
My big block runs like a stripped ape now.
Good luck
Old Sep 24, 2023 | 02:49 PM
Chaddyboy's Avatar
Good luck
what bracket did you use.
Old Sep 24, 2023 | 03:05 PM
Sharp38's Avatar
Car: 1938 Chevrolet
Engine: ZZ 502
Transmission: 4L60
I used Lokar stuff. You can check their website. They have cables, brackets, etc.
On mine, the lower one is the 700R TV. The two upper ones are the cruise control and the accelerator cable.
Old Sep 29, 2023 | 04:13 PM
BBCSwap's Avatar
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
That looks real nice. Good job. I hope mine turns out that nice. How much hood clearance do you have? Stock hood?
92kylecamaro
Nov 9, 2016 01:23 PM
Iroc-Dennis
Carburetors
Feb 12, 2013 01:43 AM
89RsPower!
May 9, 2007 09:55 AM
BigBoi4Lyph
Dec 28, 2006 11:05 PM
dennis6
Sep 6, 2003 04:24 AM
