Throttle cable different?tpi and carb
Old Oct 25, 2009 | 11:04 AM
Iroc-Dennis's Avatar
Car: camaro iroc-z
Engine: 355 L98 Corvette engine
Axle/Gears: 3.27 9 bolt borg warner
hey
anyone now off the trottle cable is different from the tpi and carb cars?
i wanna now because i start with a tpi to carb swap!
got no automatic!! i use the T-5
dennis
Old Oct 25, 2009 | 01:45 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
Re: Throttle cable different?tpi and carb
yeah they are different I think the carb cable is shorter. better off getting lokar stuff to replace it.
Old Oct 25, 2009 | 04:21 PM
Car: camaro iroc-z
are you sure or not?
i ask it because i never read it in any tpi to carb swap thread!
nobody talk about it!
is there a good part nr off it?
thanks dennis
Old Oct 25, 2009 | 04:58 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes, the TPI cable is much longer than the carb cable.
You could try looping the TPI cable around to get it where it should be for the carb, but you would be better off getting a proper short cable.
Old Oct 25, 2009 | 05:09 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
The TBI cable will work fine as well - maybe get one cheaper than a brand new Lokar or something else.
Old Oct 25, 2009 | 05:33 PM
Car: camaro iroc-z
thanks all
dennis
Old Feb 3, 2013 | 05:19 PM
Toxicant's Avatar
Car: 1988 Firebird Formula
Axle/Gears: 3.23 4th Gen w/ powertrax locker
I just swapped my 88 tpi 305 to a carbed 292 and kept my stock throttle cable specter makes an adapter that lets the stock cable more or less clip in.
Posted from Thirdgen.org App for Android
Old Feb 12, 2013 | 01:43 AM
Eighty8IrocVert's Avatar
sending question to toxicant so as not to hijack this post.
9192camaro
16
Feb 3, 2019 12:21 AM
timonator
Aug 13, 2015 11:27 PM
fonzie85
Aug 13, 2015 11:50 AM
Sanjay
Aug 12, 2015 03:41 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
