fuel regulator
Old Feb 18, 2026 | 12:16 PM
2irocs's Avatar
Car: 1989 Iroc Camaro
Engine: 383 Stroker-Carb Blue Print Engine
Transmission: automatic
fuel regulator
Put a new BPE 383 stroker engine in my 89 Iroc with a carb setup...problem I am having is having to re set the Holley fuel regulator 12-841 to 6psi each time I start the engine...sometimes it will be on 6psi other times the pressure will be below or higher than 6psi...have 6 an fittings for the supply...the return is 5/16 which is stock on our cars...is the return to small and should I go to 6an lines or 3/8 hard line...if so may buy a new metal fuel supply line 3/8...Called Holley and someone is to call me back...Thanks Larry
Old Feb 18, 2026 | 12:47 PM
2irocs's Avatar
Re: fuel regulator
Update: spoke to Holley and was told the return line needs to be as big or bigger than the supply line...
Old Feb 19, 2026 | 08:35 AM
BBCSwap's Avatar
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
Re: fuel regulator
You didin't say how much above or below set pressure it goes. If you are in between 4 & 9 you should be good. I have a holley fuel pressure regulator on my 91 and I am using the stock fuel lines, pressure & return.
Old Feb 19, 2026 | 10:02 AM
2irocs's Avatar
Re: fuel regulator
It goes as low as 4.5 and high of 7.5 psi...will put a new 3/8 line for the return see if it stabilizes the regulator...thanks for your response...
Old Feb 20, 2026 | 08:25 AM
Manic Z's Avatar
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
Re: fuel regulator
What is your fuel pump setup?
Old Mar 3, 2026 | 05:54 PM
2irocs's Avatar
Re: fuel regulator
Update: Replaced the Holley 12-841 regulator with a Aeromotive bypass regulator #13220...has two stages one Aeromotive 0-100 high pressure guage #15633 too a low pressure 0-15 psi guage...have the high pressure guage #15622 set at 14 psi and the low pressure guage at 6 1/2 psi...the pump was putting out 70 psi...I drag race my Iroc and needed to be sure I was getting the right fuel pressure without any pressure fluctuations...wasn't cheap but well worth the money...I also increased the return line with Evil Energy nylon braided fuel hose to 3/8...
Noahshenk
Carburetors
Mar 29, 2023 03:04 PM
robbyk85
May 21, 2012 11:18 PM
marine68
Carburetors
Nov 24, 2010 09:26 PM
Rob 97 Z28
Carburetors
Dec 8, 2009 10:32 AM
estone06
Carburetors
Dec 31, 2006 06:26 PM
