how do you check the TPS
Old Feb 8, 2002 | 10:00 AM
1986redbird's Avatar
I need to know how you go about checking the TPS on a ccc-quad, I have a digital volt/ohm meter and need to know where to hook it up to (which wires).
Old Feb 8, 2002 | 10:23 AM
follow-up
I just checked the TPS with my volt meter and got some strange reading: with key on but engine off (at idle 4.38 volts-at WOT .98 volts) tried changes meter leads and got (at idle -4.38 volts - at WOT -.98 volts) whats up with this ??????
need help with this bad !!!!!!!!!!!!!!!!!!!!!!!
Old Feb 8, 2002 | 06:48 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What wires are you measuring between?
You should measure from blue (B - output) to black (C - ground).
GTAman
Sep 21, 2015 09:57 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
