Carb problem solved, now another
Old Feb 15, 2002 | 07:38 PM
GregN's Avatar
Hey guys,
I got my CC Q-Jet mixture kit from Pep Boys and did the work today. I found my bog problem. It wasn't the secondary air flap adjustment. When I pulled the air horn off the carb I found the two brass pickup tubes that go to the secondaries laying in the float bowl! I guess after 126000 miles they worked themselves out.
Car ran great after I started it up. Went to Pep Boys again because the friggin connector to the solenoid broke. After reinstalling the connector, I started it up, the solenoid was clicking, but the engine was running like cr*p.
Any ideas?
Thanks,
UPDATE: Found the problem. One loose vacuum hose. Still having problems with my TC hunting between lockup and unlocked though.
Old Feb 15, 2002 | 08:21 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
A minor ignition miss-fire will be quite noticable
when the torque converter locks up at low rpm
so the first thing to check is the ignition system
check for a faulty rotor, cap or/and wires. a weak coil can do this too.
Most trans shift kits have a new set of valvebody springs to adjust the lockup rpm of your converter a little higher to avoid hunting.
The converter lockup soenoid could be shabby too. Check the ground connection between the engine,battery and body.
Old Feb 15, 2002 | 08:40 PM
GregN's Avatar
Thanks F-Bird. I have new cap, rotor, wires, and plugs. The engine runs great now. No misfire, just the TC problem. I'll check on that solonoid though. Thanks,
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
db057
Sep 4, 2015 07:57 AM
CORV3TT3
Aug 23, 2015 11:26 AM
theurge
Aug 21, 2015 12:46 PM
