Off idle stumble... TPS or something else?
Old Oct 3, 2000 | 07:42 AM
Biochem's Avatar
Car: 2002 SOM z28
I guess my TPS voltage is a little off. It reads about 0.6-0.7V at the lowest setting I can adjust the engine too (curb idle screw) without stalling. Ed mentioned that I need to turn that little torx screw with a special tool to set the TPS minimum voltage.
With that being said, is there anything else that can cause my engine to stumble when I accellerate? I have to flutter the peddle in order to keep from stalling if I go from a dead stop. It gets better as the carb warms up, but never completely goes away. It idles fine... only when I hit the gas (mildly or wildly).
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock... all the suspension stuff... 9-bolt posi disk is in... K&N filter... 93 octane...
-=ICON Motorsports=-
Old Oct 4, 2000 | 09:44 AM
Biochem's Avatar
Car: 2002 SOM z28
So with the bigger cam, should I be thinking about switching to GM#7029922 for a lighter power piston spring? What about jet and rod sizes. I think I am getting enough gas off idle. In fact I may be getting too much. Is 0.074 too big?
92firebirdguy
Sep 1, 2016 07:53 AM
earlpote
Sep 12, 2015 11:55 AM
pacoelrapido
Sep 11, 2015 02:41 PM
IROCtometal
Sep 9, 2015 10:01 AM
