Quadrajet from the 305 to a 350?
Old Oct 25, 2000 | 12:02 PM
chris83z28's Avatar
I have a computer controlled quadrajet from my old broken 305 that I am going to put on a new 350. The 350 only has 250hp and 304ftlbs. Will the old quadrajet supply enough fuel to the 350?
Old Oct 25, 2000 | 12:17 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Your q-jet will work fine. You may need to adjust the idle speeds, and should tune the secondaries after you get the engine broken in, but other than that, it'll to the job.
For the ZZ4 conversion, the factory has you use your old q-jet with new secondary rods & hanger, and that engine has 350+ hp. That should say it all right there. As a matter of fact, if you have an automatic tranny, you might consider that conversion if your budget can handle it. It's a sweet kit, has everything you need including instructions.
To add to that, the electronic q-jet has flow capability that exceeds the rating of the Edelbrock I have on my 396. It's a very versatile carb.
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 2.73 open. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, exhaust, paint, etc.).
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Jake_92RS
Jan 28, 2020 10:37 PM
colton_carlson
Mar 8, 2019 12:21 PM
Infested
May 22, 2018 11:56 PM
Dwayne614
Sep 28, 2015 08:33 AM
st.evel07
Aug 13, 2015 06:15 PM
