Anyone ever used a TOMCO rebuilt qjet carb?
Old Oct 24, 2000 | 11:50 AM
Disco Man's Avatar
Car: 1982 Trans Am
Engine: LU5 - Cross-Fire
Transmission: TH-200C
Axle/Gears: 2.93
If so what were your experiences with it, good or bad? TOMCO makes a remanufactured qjet that should be the same part number of the one I will be replacing on my T/A. Just need to know if they do a good job with rebuilding their carbs. Thanks
Disco Man
1982-83 Cross-Fire Trans Am Site: http://members.xoom.com/the305cfi/
1979 (L78/W72) 10th Anniversary Trans Am
1982 (LU5) Trans Am
Old Oct 24, 2000 | 02:29 PM
zee28's Avatar
Car: 86 iroc
I purchased two of these carbs from so-called rebuiders.I call them mass-rebuilders.just so you know,my old q-jet has been on since and I returned the 2 carbs.1 of them I gave two chances and the second one was crap too.they said it was my car,but it runs good with the old 1,the bushings are just old.I cant say anything bad about this company because im not sure the name of the second company.the first one was american rebuilders.keep in mind though,alot of these companies are weaved together,they just dont want you to know that.check them out good.or save yourself the hassle and send youres out to THE CARB SHOP.yes it will be more money,but well worth it.
~mike~
1 superclean 86IROC-Z
Old Nov 1, 2000 | 12:29 PM
jrr's Avatar
jrr
My experience with TOMCO carbs has been none too good. I had a 1966 Cadillac Coupe deVille with a Rochester RFB; ancestor to the Q-Jet. I went to a parts place and went through FOUR TOMCO carbs! All were missing key components, such as the vacuum-controlled float adjuster and the hot-air bleed. One idled fine, but the engine ran lousy with all of them. I went on and rebuilt the original. The Caddy ran fine after that.
Old Nov 21, 2000 | 11:13 AM
Disco Man's Avatar
Car: 1982 Trans Am
Axle/Gears: 2.93
Thanks for the info, I will stay away from Tomco. I will just find a core and rebuild it myself.
Disco Man
1982 (LU5) Trans Am
pjsparts
Oct 29, 2025 06:39 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
scottmoyer
Sep 7, 2015 07:06 PM
GeneralIesrussi
Sep 3, 2015 03:23 AM
