Sticking accelerator pump
Old Dec 1, 2000 | 01:48 PM
David Trimble's Avatar
I've noticed that sometimes the shaft portion of the accelerator pump 'sticks' after being pushed down- that is, it doesn't follow the pump lever back up when the pedal is released. This seems to happen only when the engine is cold-once it's warmed up it stops. I don't think the pump itself is sticking (it's a new assembly btw- I replaced it a few months ago), but the shaft is sticking on the o-ring that's in the body of the carb. I tried lubricating the pump shaft with graphite and while it would work for a day or so it'll go back to sticking again. Could I use light machine oil at this point without having to worry about any build up of dirt, which would just add to my problems?
Thanks!
Original owner - '84 T/A w/stock 305HO 5-speed
Old Dec 2, 2000 | 11:55 AM
Joey1986Z's Avatar
Car: 1986 Z28
Engine: Code "H" LG4
Mine is doing the same. Let off the pedal and the pump remains stationary and after a second or two it slowly rises to the lever. I checked my father's Chevy PU non CCC Q jet and it immediately follows the lever back to the top.
Anyone?
1986 Black/Gold LG4 Z28
Original Owner, 200,000+ near trouble free miles.
Mostly Stock.
1995 Dark Red Metallic Corvette Coupe Original Owner
Old Dec 2, 2000 | 08:02 PM
Damon's Avatar
I don't even use the o-ring. Have run my QJets for years and years without them. Never a problem. If you're going Baja/off-road racing then probably not a good idea but for a street car, you'll never miss it.
Old Dec 2, 2000 | 11:24 PM
True, and in hindsight I would've/should've left them off when I had the carb apart. However I'd rather not have to open up the carb again just to take the o-rings out...
BewleyBizzIROC
Sep 7, 2015 08:05 PM
lt1z350
Aug 28, 2015 05:57 AM
Bert87
Aug 23, 2015 03:50 PM
Wife'sCar
Aug 22, 2015 01:46 PM
Bryan F
Aug 18, 2015 02:28 PM
