Open element for LG4....
Old Nov 9, 2000 | 03:11 PM
Dan87IROC-Z's Avatar
Where can I get one, how much will it cost. I am asking for a friend, he has an 85 Z28 with the LG4, his only mod is the Hooker cat-back. He won't be getting a ram air hood for it for some time, but how much will this help, and again, where can you buy one and whats the cost?
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Components, K&N Filters, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Old Nov 9, 2000 | 11:51 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Look for a dropped base, 14x3 unit. I believe I picked mine up from Pep Boys. It was a couple of years ago, but I think it was around $15 at the time.
I noticed a couple of tenths consistently with the open element vs. the stock single snorkle, with basically no other mods.
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 2.73 unlimited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, exhaust, paint, etc.).
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Nov 22, 2000 | 03:47 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I bought the Edelbrock 41x3 drop base open element air cleaner from Advance Auto parts for $39.95. made a big difference over the single snorkel air cleaner.
Zepher
'86 Pontiac Trans Am WS6, 5 Speed:
Edelbrock 1406 Carb, Edelbrock Performer RPM 7101 Intake Manifold.
Edelbrock Open Element Air Cleaner: Flowmaster Exhaust, 160* Thermostat,
Grant GT Steering Wheel, MSD HEI Coil, Taylor 8mm Wires, Recaro Seats,
Alpine CD+Changer,Rockford & Soundstream Amps, Premier TS-1040C Subs, Polk Audio highs/mids.
WS6 Trans Am
Old Nov 22, 2000 | 09:53 AM
Damon's Avatar
And you get to hear all four of those barrels screaming at full throttle! The call of the wild!
Old Nov 25, 2000 | 04:36 PM
What does one do when installing an open element with the various vaccum lines that are attached to the snorkle and such?
L98 TPI 350 (5.7L)
Soon to come: LT4 HOT Cam, Air Flow Research 190cc or 195cc Heads, 2800 RPM Stall Converter and SLP 3.70 Rear End Gears.
Old Nov 25, 2000 | 04:38 PM
L98 TPI 350 (5.7L)
Old Nov 25, 2000 | 05:37 PM
Biochem's Avatar
Car: 2002 SOM z28
There should be a vacuum line that ran to the TAC sensor in the intake snorkle... plug that off with a cap.
There should be a hose going from the passanger side valve cover to the air cleaner... get a $5 breather and plug that up too.
14x3" drop base (in case you ever want to put on a Performer RPM intake or 1" spacer ) works great. That should be about $20 or so at the autoparts store.
I always notice a difference when I have to stick on my single snorkle air cleaner for the day that I have to get e-tested!
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock... all the suspension stuff... 9-bolt posi disk is in... K&N filter... 93 octane...
-=ICON Motorsports=-
Old Nov 27, 2000 | 06:04 PM
Thanks guys.
L98 TPI 350 (5.7L)
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Components, K&N Filters, All Free Mods, Falken ZIEX Z-Rated Tires.
Soon to come: LT4 HOT Cam, Air Flow Research 190cc Heads, 2800 RPM Stall Converter and SLP 3.70 Rear End Gears.
Old Nov 28, 2000 | 01:37 PM
chris83z28's Avatar
Be carefull with hood clearence. I you are running a 14x3 with a 1" spacer, it will not clear the hood, or at least mine did not. I had to cut the spacer down to 1/2 inch to make it work. Just check hood clearence, you can use silly puddy or playdough. I dropped 2 tenths with that mod.
1983 Camaro Z28
Goodwrench 350ci V8, Edelbrock TES Headers, Flowmaster Catback, MSD 6al and Blaster 2 coil, Edelbrock Performer intake, Edelbrock Performer 600cfm carb. T5, 373 rear, Eibach springs, Cervin Vega speakers, Rock. Fos. Sub, Pioneer CD,
email-chris4421@hotmail.com
"I used to be a Mustang Guy! I didn't know the power of the dark side!!"
Old Dec 1, 2000 | 08:03 PM
Joey1986Z's Avatar
Car: 1986 Z28
Engine: Code "H" LG4
I first purchased an Edelbrock 14X3 round drop base and it would not clear all the junk at the front of the carb, preventing a good base seal. I added a 3/4" spacer and all was well. Shortly thereafter, a friend gave me an Edelbrock with K&N. It is triangular shaped and does not require a spacer. It also provides better access to the carb for adjustments without removal. I love it! The whole thing sells for 70 at Jegs.
1986 Black/Gold LG4 Z28
Original Owner, 200,000+ near trouble free miles.
Mostly Stock.
1995 Dark Red Metallic Corvette Coupe Original Owner
[This message has been edited by Joey1986Z (edited December 01, 2000).]
Old Dec 5, 2000 | 08:44 AM
chris83z28's Avatar
Joey1986Z, is that the foam air cleaner? Beware and check it often. I had one on a jeep and it began crumbling apart and the carb sucked up the little pieces of fuzz. It had a hole through the element in less than six months. Never agian for me. Just watch it carefully.
1983 Camaro Z28
Old Dec 5, 2000 | 08:46 AM
chris83z28's Avatar
opps, did not see the K&N part, I guess not:0
1983 Camaro Z28
Falcon50
Aug 22, 2020 03:26 PM
Pac J
May 17, 2020 10:44 AM
FueledSoul
Sep 29, 2015 08:58 PM
drumstixer
Sep 29, 2015 03:02 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
