cold air induction?
Old Dec 30, 2000 | 09:22 PM
63impala's Avatar
cold air induction?
i have a 92 camaro with a 305 tbi i was wondering if anybody makes or how i could make a cold air induction system for it
Old Jan 1, 2001 | 06:28 PM
Damon's Avatar
You can rig up a very good flowing and relatively cheap cold air/ram air setup with a generic 14" open element air cleaner (3" filter, 1 1/2" drop base- jsut like you'd buy at the local auto parts place in the "performance" section.
Then check out the products at Air Inlet Systems (ramairbox.com) for a cold air system that will basically wrap around the air filter assy. and give you your coice of cold air induction methods- dual 4" snorkels, snorkels that match up with a cowl induction hood, etc. etc. They've got tons of systems for well under $150.
One note- you will have to do a little trimming with the AIS cold air systems back by the distributor- they won't clear without a little work. But they are made of fiberglass so trimming for a good fit is really simple, even if you are using a large cap HEI distributor.
Old Jan 3, 2001 | 09:48 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You might get lucky at a yard. I found a dual snorkel from an HO car for $30. I purchased the scoops and ducts from GM.
JamesC
Damon, thanks for the info on the secondary metering rods. Since I'm not a racer, I went with the AH rods and the G hanger. I'm very pleased and impressed with the results.
83 Crossfire TA
Jan 3, 2016 01:26 PM
86iroczwv
Sep 3, 2015 06:21 PM
IROCtometal
Sep 2, 2015 02:01 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
kyle5647
Aug 15, 2015 11:56 PM
