Cam guys.... what cam?
I'm just about to convert from TBI to carb and then a month later (after saving my pennys) I'm going to put a new cam in. The engine is a 305 and i'm going to use the stock springs for now so I can't get to high.
These are the cams i'm looking at
duration i/e : gross lift i/e : lobe separation
214/224 : .444/.467 : 112
220/231 : .468/.480 : 110
214/214 : .444/.444 : 112
213/213 : .447/.471 : 112
215/218 : .489/.503 : 115
215/224 : .489/.489 : 112
219/227 : .471/.480 : 112
they are all hyd roller cams
laters...
laters...
Good cam...probably the best one on the list for you.
This would be the one I would pick..if it were me. You're prolly not willing to live with the poorer streetability that I am though.
Crap. Always look for a dual pattern cam unless you have GOOD aftermarket heads.
Same problem as above.
Crap. The LS is way too high.
Bout the same as the first one, just more lift. Would make it a better choice if you had valvesprings to match.
ehh....it's ok.....
But I wouldn't really use any of those with the stock springs. You'll need to upgrade.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
ehh....it's ok.....
JSP Motorsports
ICON Motorsports
I'd change the springs if at all possible along with the new cam. While there I'd get rid of the exhaust valve rotator/retainers and use a standard set of retainers that way you can use the same springs exh and intake and not have to resort to more expensive sets that have different springs for the exhaust. I agree with Jester on the cams. Don't let the fear of changing springs stop you from putting in the cam you want.
Car: 2002 SOM z28
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
i would agree with every one else, get the first one. its good to see you not going to let the springs limmit your cam choice, but you heads should. stock 305 heads arnt the best flowing heads in the world. if i had stock 305 heads i would go with anything over .500 lift. to much duration would bleed of cylinder presure and leave you with a soggy bottom end. stick with something below 224 @ 0.050
when the green flag drops the bull$hit stops
Curent: 350,performer RPM intake ,650dp, 700r4, headers, 3inch exhast
Spring 01: 406, Comp 282 solid cam, 2400 stall converter, every thing else the same.
