Main mixture screws on a non-computer gmc qjet?
Car: 82 Trans am
Engine: Twin turbo 350
I just put in a late 70s 350 from a GMC truck, and the Carter mechanical carb went in with it. My computer controlled qjet was acting up with my old 305, so i didnt want to put it back on. Now, the car is running really rich, as in leaving black streaks on the pavement where its parked. The idle screws are about 1 turn from all the way in. I was wondering where the main mixture screws are on this carb, and how do i adjust them. sorry if this is a stupid question, but i havent been able to find any info b/c I dont know the model number.
Thanks.
Thanks.
You mean where are the mixture screws on the Carter? They're staring you right in the face when you yank the air cleaner off. 2 screws, one per primary throttle bore, pointing up from the base of the carb at a 45* angle on the front of the carb. Those are the idle mixture screws. Anything above idle speeds they don't do anything, though. Above idle speed the a/f calibration is handled by the primary jets and primary metering rods.
On the QJet the idle misture screws are concealed behind factory tamper-proof caps. There's a reason for that- the computer in the car adjustes the carb's a/f mixture on the fly via a mixture control solenoid (big blue two wire plug on the top of the carb). BTW, if you run a computer controlled carb without the computer connected (or functioning properly) the carb defaults to full-rich and the engine will run like crap.
Oh yeah- adjusting them. Turning them in clockwise leans the mixture, CCW richens it. Make sure you keep them a fairly even number of turns out. Don't set one at 3 turns out the other at 1.
skinny z
Oct 5, 2015 06:23 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
gta892000
Sep 16, 2015 12:37 AM
