CFM?
Old Jan 15, 2001 | 04:58 PM
84TransAm's Avatar
CFM?
What CFM should i get for my stock LG4? I'm going to dump that Quadrajet and get a Holley sometime this summer and wondered which one is big enough? Also what part number would be appropriate?
Whenever I "Fix" my car, something always "breaks"
1984 Trans Am 305 LG4, 5 speed Auto
RPO codes point to Recaro version, want to put a 500 Cadillac in but money is on a vacation...
Mods
    More coming...
    P.S. Daily Driver
    [This message has been edited by 84TransAm (edited January 15, 2001).]
    Old Jan 16, 2001 | 07:34 PM
    Damon's Avatar
    If the motor's never going to see the high side of 5500 then a cheap 600 cfm vac secondary carb will do just fine. If you plan on moving up to a 350 (or larger) or otherwise working it over for some serious horsepower in the near future then I'd go with a 750 for starters, maybe more. The QJet you're taking off flows 800 CFM with minor tweaking, by the way.
    Old Jan 16, 2001 | 08:41 PM
    CamaroMike's Avatar
    Damon a 100% volumetricly efficient 350 at 6000 RPM only flows like 640 CFM. ****, even the best thirdgen without power adder is only at 90% VE and thats like 576 CFM. Don't get a big carb you will only loose torque and kill throttle response! 600 CFM is plenty. Hell, I have run 12.98 on an Edelbrock 600.
    84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
    Other Mods: You name it and I have probably changed it.
    2001 Dodge Ram Quad Cab 5.9L 4*2
    ASE Certified Auto Tech
    LIVE AND DIE BY THE ALMIGHTY BOWTIE!
    PurelyPMD
    May 5, 2016 04:57 PM
    sreZ28
    Oct 22, 2015 08:21 AM
    randy210
    Oct 15, 2015 03:43 PM
    okfoz
    Oct 13, 2015 02:19 PM
    Dragonsys
    Sep 25, 2015 03:51 PM
