should i swap a carb instead of tpi?
hey guys i was wondering what you think of swapping an edelbrock 600 cfm and airgap intake on my lb9 305 instead of the tpi.
the entire engine combo is retrofitted into an 86 442 with a 200 4r and 3.73 rear, using all parts from a z28, accept the wiring, and fuel pump(used an inline from nos) it has an adjustable reg, and a thermomaster chip. the engine idles at 900rpm, and doesnt get the kind of mileage i thought the injection would get(only about 20mpg) other wise it runs good,no troublecodes, and passed emissions with flying colors.
my friends car runs a edelbrock 600 and it runs smooth and clean and kicks my cars butt in mileage with the same displacement, but bigger cam,because i dont like the inline pump, and dont feel like paying 300 dollars for a intank, im thinking of doing this,
do you think i will pass emissions with no egr, computer, a 600cfm, and a vacuum advance? i doubt it. what are the pros and cons? i guess this goes along with the great debate, carb vs efi
I would definately go carb.
Sounds like you want to go fast now.
Don't go with an intank pump no matter which way you go.
I have no idea about NY emissions in your area. Talk to your local friends about that deal.
good luck
*I do custom performance mods on Edlebrock Performer carburetors (dualplane intake mods in the works),
White 1986 Irocz, 305/383 with Edlebrock Performer-RPM intake and Performer #1407 carburetor, +110hp shot of crack, 700R-4 tranny, 3.25:1 rear, Mcreary Road-Stars, SLP-stainless 1.75" shortie headers & Y-pipe, single 3" Borla exhaust, Linginfelter-TPI camshaft part number 74216 pulls 17" vacuum solid. Cam specs 213/219 @.050 114-LSA, .462/.470 lift @1.5:1 ratio. MSD-6AL, billet distributor, multi-retard, blaster-3 coil, and RPM switch.
N/A runs 10.9 @124,
Crack-runs 10.3 @135
haven't run at track since Oct-99
good luck
N/A runs 10.9 @124,
if you want top end hp and and hp period for half the price and hassle go carb its wayyyy beter than lousy tpi. tpi requires a lot of time and money! it always screws up and is very very expensive! stock tpi sucks! upgraded tpi is grate but again costly!
1989 firebird formula
Mods: converted from T.B.I. to a carburator 305 to a 350. Flowmater exhaust,hedman shortie hedders,202 160 (882) heads,.447/.447 lift 222@.050 duration speed pro 327/350hp cam 350 .40 over (356) Edlebrock torker2 and a 600 edlebrock manual choke (1405)
Future mods performer rpm air gap intake (polished) comp roller cam, and way better headsa 400 defintely in the works!
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Well, I ditched my TPI and the 305 it was on at the same time, and threw in a 350 w/ Vortec heads, Perf RPM intake, 750 vac sec carb, headers, and a 218/224 cam.
With no emissions equipment on the car at all, except the $99 Catco 3" cat, it passed the IM240 or whatever dyno emissions test. Passed for the standards of the 305 TPI I assume, since that was what was still listed on the sticker and I didn't tell them otherwise. Passed w/ ease actually...
I had initially tried to see what it would do with no cat on it all (well, gutted stocker) and it passed on all tests except the CO test I believe it was, where it was like 4 times the limit. The catco cat dropped to a mere fraction of the limit for that test, and even chopped the other tests numbers down some for good measure.
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
[This message has been edited by Ray87Z (edited February 10, 2001).]
Ray87Z
-Vortec headed 350.
Formerly Ray86IROC.
86IROC112
08-17-2015 02:00 PM
Sanjay
08-12-2015 03:41 PM
