QJ problem?
Old Apr 4, 2002 | 01:33 PM
83tranzam's Avatar
Car: 1985 Trans Am
Engine: LB9 5.0 TPI
QJ problem?
I recently bought an '83 305 T/A w/ the Quadrajet & was told by the previous owner that the carb needs to be rebuilt. But, I wanted to check it out with you guys first. Here's the symptoms:
Car starts & idles fine, but hesitates when accelerating @ around 4000-4500 RPM.....happens more often once engine warms up. Anyone have any experience with this type of problem? Any suggestions? Thanks!!
Old Apr 4, 2002 | 05:40 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard, if you haven't been yet.
The first thing to do is to check the ignition system: spark plugs, wires, cap, rotor, timing. If those things are okay, then fuel delivery (fuel filter, fuel pressure). If those are okay, then you can assume the carb has a problem.
The first symptom sounds like a possible accelerator pump problem. You can check that while checking the other things. With the engine off and choke open, look down the primaries and give the throttle a twist - you should see a nice stream of gas going into each venturi. If it doesn't start squirting right away, or isn't a nice full stream coming out, then you can skip right to the rebuild.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
