Question about hood clearance w/ predator carb, 700R4.
Old Mar 11, 2001 | 12:00 AM
JRoy91RS's Avatar
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
Ok, I am getting fed up with my TPI swap, and am seriously considering going carb. My questions are:
1)Will a predator carb clear the stock hood? If so, with what manifold?
2)If I go carb, how do I control the lockup on the 700R4. I currently have a 91 RS. What else needs to be done? THanks
Old Mar 11, 2001 | 12:09 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I'm not sure how tall the Predator carb is. I think it's taller than a Holley. I had a low profile manifold on my small block with a Holley and a 2" tall air cleaner that just barely fit under the hood. With a predator or larger air cleaner you may need to get a cowl hood.
There are kits available to let the torque converter lockup without a computer.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Mar 11, 2001 | 07:19 AM
The ODB's Avatar
don't compromise manifold design or aircleaner height just to fit everything under the stock hood. It will negate the benefits of running the carb in the first place.
Old Mar 11, 2001 | 11:14 AM
JRoy91RS's Avatar
Engine: 355
Great Point, ODB. (Sigh), looks like I have to consider other options. I'm not sure what to do now. I'm afraid I won't be able to get the TPI running without spending much more dinero $$$$. I know this is the carb board, but any suggestions?
Old Mar 11, 2001 | 11:19 AM
Jester's Avatar
Sure..just get a cowl hood Or just run a normal hieght carb like a Holley.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old Mar 11, 2001 | 11:25 AM
The ODB's Avatar
cowl hood
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
IROCZ1989
Sep 4, 2015 11:54 AM
