2 Barrell Question
Old Mar 5, 2001 | 08:52 PM
SS Racing's Avatar
2 Barrell Question
This is not an easy one. I just rebuilt a friend's DualJet 210c and now the car won't idle right, it backfires through the carb, and dies if you put it in gear or punch the gas. I've rebuilt MANY Q-Jets and never ran into this problem. Any suggestions? I've though that maybe the float wasn't set right so I pulled the top off and checked, all my adjustments are EXACTLY right. This one has me stumped. Please help, my reputation is one the line. Any suggestions are welcome. Thanks.
Old Mar 5, 2001 | 09:16 PM
FastBroker's Avatar
Sounds like you got some "stuff" stuck inside the passage(s) inside the carb somewhere. Or used the wrong rebuild kit and blocked some passages with the gaskets? Or got the fuel pump hooked up backwards (inlet/outlet)
OR you did some other work at the same time and the carb is fine.
Old Mar 6, 2001 | 03:41 AM
The ODB's Avatar
check the sparkplugs for fuel. If it's getting too much fuel then you may have a leaking gasket or a blocked airbleed.
Old Mar 6, 2001 | 08:13 PM
SS Racing's Avatar
I soaked the carb over night in a carb vat and I washed it out as good as possiblr the next day. I matched the gaskets with the old ones and I'm pretty sure the fuel pump is hooked up right. I haven't checked the plugs, but I will. If the idle actuator solenoid is messed up, could that possibly cause the problems I'm facing? It's about the only thing left that I haven,t checked or replaced. Anyway, thanks for the help.
1983 Z28 LG4 bored .040 over(312 c.i.) with flat tops and 9.7:1 comp.
'73 Q-Jet 750 cfm with vaccuum secondaries and automatic choke.
Future plans: Upgrade the ignition system and goin computer delete!
Old Mar 8, 2001 | 12:22 PM
Damon's Avatar
You probably rebuilt it right but got the vacuum lines back on wrong. Fer' instance- plug the EGR valve into a full manifold vacuum source and you'll have all KINDS of fun trying to get it to idle right!
Old Mar 9, 2001 | 09:24 PM
SS Racing's Avatar
No, man, I'm pretty sure I got the vacuum lines on right. There are only three, the PCV line(a big one), a small one at the front, and a small one on the back. He didn't even have the EGR functional, but it wasn't causing a problem. Tha EGR is not necesary if you plug everything off. I don't have one on my Z28. The rest have all been plugged off for a couple months and weren't causing a problem. I told you "It's a tough one". Thanks anyway, though.
Old Mar 10, 2001 | 05:15 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What was it doing before the rebuild?
Maybe it's not the carb at all...
ICON Motorsports
Old Mar 11, 2001 | 11:56 AM
SS Racing's Avatar
Before the rebuild, it was getting poor fuel mileage and idling a little strange, but not as bad as it is now.
midge54
Jan 29, 2017 07:00 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
neekolzun
Aug 24, 2015 04:59 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
