carb swap fuel pressure regulator question
Subscribe
Apr 5, 2002 | 07:37 PM
can i use a regular 2 port FPR when going from TBI ro carb and keeping the stock pump? can i just plug the return line?
thanks
Reply 0
Apr 6, 2002 | 04:51 AM
I went to a performance shop to see what I should do,and they recommended getting a regulator with a return line port. I have a 4 port adjustable Mallory that is really nice.The part number is 4309.
Reply 0
Apr 6, 2002 | 08:49 AM
A two-port only blocks the outlet pressure from going higher than the set pressure. That's intended for a pump with internal bypass/relief, like a mechanical pump.
In-tank electric pumps don't like being blocked off with no flow since they don't have any internal relief or bypass. So, get a 3-port with return line.
Reply 0
Apr 6, 2002 | 02:58 PM
If you don't get a return style reg, you will burn your pump up.
:hail:IROC-Z
Reply 0
Apr 7, 2002 | 02:28 PM
i thought the mallory regulator part number 4309 was a 3 port maybe i am wrong but that is the one i just ordered from summit 74 dollars and some change for it.. summit said its a 3 port but anyways..
Reply 0
Apr 7, 2002 | 08:32 PM
Quote:
The part number on the box I have is 4309. It has a return port at the bottom and four in/out ports around it with the pressure adjustment on top along with a vacuum port.If I remember right,it cost me about $108.
Reply 0
Apr 7, 2002 | 10:03 PM
so my only option is the 70 something dollar mallory one?
Reply 0
Apr 7, 2002 | 10:55 PM
P/N "MAA-4309" on summit is what you want
Reply 0
Apr 8, 2002 | 12:28 AM
Quote:
Is this the one you have? I noticed in your sig you have a three port.Mine is a four port with the 4309 PN. Just curious if the one in your sig is the same PN.Maybe my PN on the box is wrong?
Reply 0
Apr 8, 2002 | 12:11 PM
They are the same regulator. Technically it has 5 ports. 4 of them can be used for Supply and Feed and one is for Return. So I guess it can be called either a 4-port regulator (since it has 4 supply/feed ports) but in reality its a 3-port "style" regulator because it does 3 things. Supply, Feed, and Return.
Reply 0
Apr 8, 2002 | 07:04 PM
Cool.Thnx for straightening out the confusion.
Reply 0
Subscribe
