Jester Ive read, and you da man!
Old Mar 17, 2001 | 09:18 PM
AustinT's Avatar
This is for Jester or anyone who might know. I am doing a Tbi to Carb swap. I have the mallory regulator with the return. I want to put the regulator over on the driver side on one of the strut bolts and run a line over to the carb. Is there anything wrong with putting the regulator 2 feet from the carb. I dont want to starve the carb. The new intake I am using has bolts that go strait down to bolt it on the old manifold had the angled bolts. Does anyone make a bracket That will bolt up to the New Manifold, Carb and Throttle Cable
Old Mar 17, 2001 | 11:09 PM
Jester's Avatar
There is no problem with putting the regulator a few feet away, the strut tower is fine.
No one makes such a bracket, but all it takes to make the stock one bolt up is a little grinding and hole elongating.
Happy Carbing
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old Mar 17, 2001 | 11:22 PM
84FTA's Avatar
Hrm. Doesn't Holley make a bracket that bolts to the manifold? Or does it just not fit our cables?
1984 WS6 Hardtop Trans Am
Former L69 Car under restoration
1984 T-top Trans Am
4-bolt main 350, performer intake, headers, Holley 650, T-5, hayes clutch, dual elec. fans and 3.23's.
Daily driver and restoration
13.98 @ 101
Old Mar 18, 2001 | 02:02 AM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Not sure exactly what you're asking about the bracket. If you're just looking for a throttle cable/TV cable bracket to bolt to the carb, then yeah they make one. Holley makes a couple different models, as do several other companies. You can get them from Jegs or Summit. <a href="http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=1742&prmenbr=76&path=76%202317%202344"> Here </a> are the Holley ones Jegs has, browse around their catalog for other types. (I'm using "E" in the pictures on my holley carbed engine, car was originally equiped w/ TPI BTW.)
I have my Mallory regulator mounted right above the drivers side valve cover. I just secured the little bracket the Mallory reg came with with the centerbolt valve cover's front bolt.
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
[This message has been edited by Ray87Z (edited March 18, 2001).]
Old Mar 18, 2001 | 10:27 AM
AustinT's Avatar
Yeah Im just looking for a Bracket To So I can use my Stock Throttle cable with my Holley and My intake Manifold. The intake Manifold has 8 bolts that hold it down, and the bolts drop strait in, they are not angled like the old design. How does the throttle cable bracket you have mount?
Thanks everyone
Old Mar 18, 2001 | 01:10 PM
Ray87Z's Avatar
Car: 94 Z28
Axle/Gears: 3.23s
The throttle cable I have mounts on the back bolt that holds the carb on, the carb has a little slot that positions it correctly. It works w/ the stock TPI throttle and TV cables, I assume the TBI ones are the same.
Ray87Z
-Vortec headed 350.
Formerly Ray86IROC.
Old Mar 18, 2001 | 06:33 PM
AustinT's Avatar
Hey Ray would Which bracket would I need for Using the Cruise control and the Throttle cable. I am going to call summit in the Morning and order. '
Old Mar 21, 2001 | 11:36 PM
AustinT's Avatar
recieved my Bracket today from summit and it works perfect Thanks Ray
Bubbajones_ya
Jul 6, 2024 08:32 PM
sahlomonic
Sep 20, 2015 07:15 PM
eustodp
Sep 20, 2015 05:09 PM
Rally Smith
Sep 14, 2015 06:59 PM
sandman92084
Sep 12, 2015 10:27 PM
