tbi to carb
Old Mar 20, 2001 | 09:19 PM
Brentis007's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Transmission: Manual 5-speed
Axle/Gears: stock
tbi to carb
I searched all over the archives and couldn't find a good answer. I need to know exactly what modifications it takes to turn my 305tbi into a 350 with carb. I'm talking mainly about what I have to do with the computer and the intake and things to make the carb work right. Thanks
Old Mar 20, 2001 | 10:21 PM
The ODB's Avatar
you don't turn a 305tbi into a 350carb'd.
you remove the 305 & tbi,
then install a 350 with intake, distributor, and carb.. along with an inline fuel pump to match your carb like a CArter electric.
Old Mar 22, 2001 | 08:42 PM
Brentis007's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: stock
I know you can't "turn" a 305 into a 350. I am getting a 350 and wanted to know what to do to use a carb instead of the tbi.
Old Mar 23, 2001 | 05:03 PM
Tom Batts's Avatar
Old Mar 23, 2001 | 08:37 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
Here is what i did with my Cross fire car when I swapped it. I found the power wire for the electric fuel pump and wired it to a switch on the dash(ultimate anti theft system)and just routed it to a AFPR and there you go all you need is a vacuum advance dist and a 350 with a carb.
Old Apr 3, 2001 | 12:09 PM
Holland's Avatar
There is a whole article in the Tech section on how to convert a TBI to a Carb. I think it is writen by jester. It should tell you everything you need to know.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
Billy Decker
Sep 4, 2015 03:46 PM
