Open Air Cleaner Which One?
Old Apr 8, 2001 | 11:43 PM
RadarRunner's Avatar
Car: 1987 Z28
Engine: LG-4 305
Transmission: 5-speed
Which open air cleaner for my 1987 LG4 4bbl would be the best? The only modifications is no air/smog pump & assorted plumbing. Also what do I do with the single vacuum hose that runs from the stock cleaner to the carb?
1987 Z28 Black & Silver 305 LG4/5-Speed . . .
NRA/AMA/FOP/IUPA/Blue Knights
Old Apr 11, 2001 | 11:56 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Well, no one else took a stab, so here's mine:
You'll need a dropped-base air cleaner in order to clear the hood. I picked mine up at Pep Boys, I believe it was a Mr. Gasket (it's been a few years). Less than $20, as I recall.
Just cap off the port for the vacuum line that goes to the stock air cleaner. You'll also need to do something about the fresh air PCV intake that is filtered via the small filter in the cleaner housing, with the tube that goes to the passenger side valve cover. Cap-type filters are available, but I've had difficulty finding the 3/4" size required (I've had one for a long time that I used on mine). Most are 1-1/4".
Be prepared for changes in the way the car runs on the street. Especially negatively in stop-and-go traffic in hot weather.
Old Apr 12, 2001 | 12:18 AM
84TransAm's Avatar
Summit sells one with their name on the top for $14 or so and $20 to have no logo.
--Steve S--
1984 Trans Am 305 LG4, 5 speed
Daily Driver, Flowmaster 80 Series
Holley 600 cfm & vacuum advance
Old Apr 12, 2001 | 05:12 PM
five7kid's Avatar
The only one I found in their latest paper catalog was a $40 "gauze" element (read: K&N) unit - that's why I didn't quote anything else.
You should be able to find a similar unit at most any store that carries even the least of performance parts.
Old Apr 14, 2001 | 04:57 PM
Joey1986Z's Avatar
Car: 1986 Z28
Engine: Code "H" LG4
After trying several. I'm staying with my $60 Eldebrok Traingular shaped housing with a K&N. Fits with no problems and provides ample room for adjustments.
I first got a generic round drop base and later had to add a 3/4" riser gasket so the base would clear all the attachments.
1986 Black/Gold LG4 Z28
Original Owner, 200,000+ near trouble free miles.
Mostly Stock.
1995 Dark Red Metallic Corvette Coupe Original Owner
Brinkkl2000
Aug 4, 2018 08:29 AM
86IROC112
Sep 7, 2015 01:37 PM
BurlyChev
Aug 22, 2015 01:52 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
