TBI to carb help
Old Apr 15, 2001 | 01:18 PM
91camaroRS's Avatar
TBI to carb help
alright i bought a maloray 3 port fuel presure regulator. now my question is is there a site or something with some step by step instructions on how to do this or can somebody help me please.
350 bored 30 over ..882 casting heads ..comp cam..hooker headers.. 700r4 corvette servo .. 3.73 and SLP posi no hood on the car , holley 750 CFM, performer RPM intake.. and umm couple other things here and there
Old Apr 15, 2001 | 08:14 PM
Blucamaro's Avatar
I don't know how much this will help but I'll try.I just did the Tbi to Carb swap and I got a holly 3 port regulator(1 in and 2 out)So what I did was,My fuel lines come out on the driver's side and I took the regulator pretty close to where the fuel lines came out,1 in,1 to the return line(usually the thicker of the 2)and ran a steel line around almost where the factory lines ran around the intake,I had to us a couple of small piece's of rubber fuel line here and there but for now it work's pretty good.Oh,and get a fuel pressure Gauge I think the holly is at 9 psi,I heard you don't need that much for a carb,but not sure..good luck!
Old Apr 15, 2001 | 11:24 PM
PPonU4Me's Avatar
All you have to do is get the necessary adapters to hook your existing lines to the regulator, the way I did it was to run my supply line in the side and return in the bottom port. Use the other open port for a fuel guage. Loosen the nut on top, and turn the allen head screw in for more pressure and out for less. Your pressure should be no more than 8 psi for Holley and 6 psi for edelbrock. Any more ques., just ask or e-mail me.
'87 Camaro Iroc-Z
'92 350 .040-over
Mild Cam
700R-4 w/shiftkit only.
Edelbrock Perf. manifold and Carb(600cfm#1406)
GM HEI upgraded with Accel parts
TBI truck Heads
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
Billy Decker
Sep 4, 2015 03:46 PM
