got my holley SA 770 today few questions!!
as i said i got my new carb today.. very nice looking and all but they sent rubber hose for the gas line on the carb.. what do u most of u use?? do u use the rubber hose?? or should i get something else liek braided line?? if anyone has pics of how they have theres set up that would be great thanks
Transmission: 4L80E/4L80E
The solid chrome line is the most typical setup. One disadvantage is you need to disconnect both bowl inlets to rejet.
I did the 4150 conversion, was explicit about wanting the 4150-version dual feed line, Summit sent me a 4160 version anyway (too short for a 4150 carb). I ended up cutting the line towards the rear and using a left-over in-line fuel filter rubber hose to splice it. Now I only have to loosen a hose clamp to take either float bowl off.
Car: 1989 C4
Axle/Gears: 307
Yea I used the 1552 also. I cant figure out what Holley was wanting me to do with the two fuel fittings and and rubber hose.
Did they sent you a Y connector with your S/A?
SSC
Did they sent you a Y connector with your S/A?SSC
yeah they sent me the y connector but its that cheap plastic crap and the rubber line would look kindof crappy to so i got that mr gasket type.. seems for the money they would send something good lol but oh well
Hey 2ponchos. I'm going to buy the Street avenger for my malibu, and I want to know what you did for the TV cable. I got the TCI bracket for the quadras&!t that's on it now, but I'm not sure the geometry is correct. I'd like to get everything right when I swap carbs. Do you have to get anything for the throttle arm to make it line up correctly? Thanks
hey what i got was jsut one that both kick down cable and the throttle cable go into.. i think a company called spectra or something simular to that makes it.. u can get on from holley part number 20-95 that is made for the 700r4 type cables but the local parts store had this one so that is what i am using hope this helps
