is there a kit i need to buy to set up my edelbrock 600?
Old May 7, 2001 | 01:44 PM
84CAMAROHIGHOUTPUT's Avatar
i'm switching my 305HO to edelbrock carb and RPM intake, the problem is i can't figure out how the throttle cable lines up. was i supposed to get an adapter kit or seperate linkage kit with it? can you use the stock stuff? any help with this matter would really be appreciated.
Old May 7, 2001 | 03:52 PM
Duffster's Avatar
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
something like this? ? ?
Duffster (age 32)
BEAT DOWN HARD 88' Camaro Sport Coupe,
1978 Caprice Classic 305 motor havin'(WITH NO COMPUTER),Torker II intake, Edelbrock 1406,600cfm w/vacuum secondaries,Accel HEI Supercoil/Cap/Rotor Sparkin',84' POS 700R4 Tranny usin', 84' Z-28 Nose clip wearin',
84' Z-28 Hood covered,
AND THE TIRES:
245/60-16 Firehawk SS20 on Firbird rim(1-passenger rear),
235/55-15 BF Goodrich's on CompTA's on Z28 rims(2-on front),
235/60-16 Pirelli P600 w/a curb check or 3 also on Firebird rim(1-drivers rear),
REAR HATCH MASTER OF ALL!!!
DuffsterCamaro@HOME.COM
Owner of the Camaro 0 out of 10 Third-genners approve of, no longer part of the non-existent Iowa crew.
Old May 8, 2001 | 12:35 AM
is that the stock throttle cable setup? looks like it, but i'm not sure. and what did you do with the brake booster line? mine doesn't fit into my new carb
Old May 9, 2001 | 05:28 PM
Duffster's Avatar
yes...stock throttle cable, but not the stock bracket...
got it at local parts store for about 12 bucks.
the vacuum is connected to the front of my Edelbrock carb which I have on now.
evilstuie
Feb 28, 2016 03:33 PM
fasteddi
Sep 2, 2015 10:29 AM
hectre13
Aug 26, 2015 08:17 AM
86IROC112
Aug 17, 2015 02:00 PM
MENINBLK
Aug 5, 2015 11:58 PM
