solved a convertible leak
Old May 31, 2003 | 11:25 AM
89rsragtop's Avatar
Car: blue
Transmission: 6 speed
Axle/Gears: 3.73 posi
Background- I was getting puddles of water in the floor and under the seats in the back seat area.I couldn't figure where it was getting in.
The tonnaeu area has drain tubes that go between the inner and outer skin just behind the doors. There are little drain holes at the bottom of this void. If they get clogged like mine did it will hold water and then overflow into the car under the rug just behind the door. I had to use a wire hanger to make a tool clear the holes. You can best get to it by removing the plastic vent grill in the door jamb. I know it sounds easy but it took me a long time to figure it out.
Just another piece of wisdom from your ol' Uncle Tommy.
Old May 31, 2003 | 12:04 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Good stuff. Thanks for sharing as I've never seen this topic before.
Willie
Old May 31, 2003 | 12:10 PM
patrickm00's Avatar
well-timed. i noticed those tubes when doing my gfx swap on my convertible, and just noticed a puddle on the passenger side this week, and wanted to take care of it before i put my new carpet in. i figured it was drainage related, but you saved me from having to figure it out...
Old Jun 2, 2003 | 02:42 PM
drop-top IROC's Avatar
Engine: 305 TPI (LB9)
Transmission: WC T-5
My prayers have been answered!
Thanks, 89rs, I'm gonna look into this further. I've had the same problem on the couple occasions that the convert. has sat out in heavy rainstorms (which, fortunately, in So. Cal. doesn't happen very often).
BTW, how bad did you have to cut up your KB subs to get them to fit? Do the rears line up correctly with the LCA bracket mounts?
Old Jun 2, 2003 | 05:42 PM
89rsragtop's Avatar
Car: blue
I have had my SFCs for a long time ,So I dont know if they are still the same.For the record no cutting and just had to bend passenger side tube up a little. I am very happy with them.
Old Jun 3, 2003 | 09:47 PM
91DropTopTA's Avatar
Car: 91 Trans Am Convertible
Engine: 300 HP 350 CI
Axle/Gears: Drums?
That's where all that water was coming from. I hope. After I put the new top on I was still getting lots of water in the floor. It rains here all the time and this has become my next project. Thanks for the great tip.
Old Jun 4, 2003 | 01:17 PM
Bill Speed's Avatar
Car: 1989 Formy droptop/88 Deville
Engine: L98 350 TPI
Transmission: factory RWD, WS6 susp
Drain tubes are not uncommon, as I was told the factory Cad sunroofs also have them, however, shots of access/ visable locations would be helpfull too.
I assume the top of the tube is not at the vent location? I've never looked on my bird. Odd
BILL
Old Feb 26, 2004 | 09:48 PM
Speedgraphic's Avatar
Car: '90 RS Vert
Engine: 305 TBI
Transmission: 700-R4
THANKS!
I've not experienced this problem yet but I am sure I will.
A plugged drain hole is probably the last thing I would look for if I were looking for a leak like this... Now I will check there first If I notice water back there...
Is there any chance of getting Pics of the drain holes. It would make them a lot easier for us to locate...
THANKS!
Speedy
Hotrodboba400
Dec 10, 2019 07:07 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
