convert top care
Old Jan 27, 2004 | 06:44 PM
louiez70ta's Avatar
Car: 70 ta 70 camaro
Engine: 455 383
Transmission: 4 speed
convert top care
hey i wanted to know how do you guys clean your tops and my rear plastic window is dull and muggy can i fix that or do i need a new top thanks
Old Jan 28, 2004 | 04:06 AM
Graboid's Avatar
Buy a new top.My plastic window was crap too. I received my new top with Glass window recently. I will post pics as soon it is installed
Old Feb 1, 2004 | 01:17 AM
Ragtop89's Avatar
Please do!
I've wanted to see a glass window install.
I'm tired of the plastic rear window impeding my rear-view.
Old Feb 1, 2004 | 01:35 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: convert top care
Originally posted by louiez70ta
...my rear plastic window is dull and muggy can i fix that or do i need a new top thanks
The plastic rear window needs to be protected from the UV. The ultraviolent rays cause it to discolor, turning brown. The bad news is that no amount of plastic cleaner will rescue it at that point. The good news is that the entire top doesn't need to be replaced. If the rest of the top is in good shape, you can have an auto upholstry shop sew a new rear window for much less than the price of replacing the entire top. I had a new rear window sewn into mine for roughly $125 about 3 years after I bought the car. That was 8 years ago. I've protected the window from the UV since then and the window is still in good shape.
Lon
Old Feb 26, 2004 | 07:25 PM
irocdan's Avatar
Car: 88 Iroc vert
Engine: 305 tpi. cts-v brakes
Transmission: Tremec T-56
well what did u use to protect it with ,lon? btw i still need my hinges done but the tags are expired n now i need to smog my iroc with my cracked exhaust.....
Old Feb 28, 2004 | 10:59 PM
Droptop_Z's Avatar
Car: 88z
Transmission: t-5
I use meguiars plastic polish to protect mine and havent seen any problems.
Old Mar 8, 2004 | 05:29 PM
drop-top IROC's Avatar
Engine: 305 TPI (LB9)
Transmission: WC T-5
Any good cleaner for plastic windows will work, but the most important part is to use a VERY SOFT, CLEAN CLOTH when polishing it. I forget what the name of the cleaner I use it, but I picked it up a few years ago at boat/marine canvas shop. It is made specifically for heavy-weight plastic windows.
1992 Trans Am
May 10, 2023 07:19 PM
69 Six Pack
Oct 5, 2015 07:51 PM
yankeecarman
Convertibles
Aug 23, 2015 07:47 AM
Dan Hubbard
Aug 12, 2015 09:05 PM
