1988 convertible deck limit switch
Old May 7, 2004 | 08:01 AM
zooker's Avatar
The switch for the tonneau cover is located on the console. Switch does not actuate the solenoids to open cover. GM had a service bulletin about a deck limit switch that must be actuated for the switch to work. Any ideas on where the switch is located? The switch on the console is good and the solenoids check good. Any pictures or answers would be appreciated
Old May 7, 2004 | 10:20 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I'm not familiar with such a switch. They may be referring to the striker-sensing switch which is the small black switch on the hatch pull-down unit next to the latch.
Lon
Old May 7, 2004 | 11:31 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It is located in the center rear of the end panel. To operate, parking brake must be applied (MANUAL) and release switch held. For automatics, gear must be in "P" or "N" and release switch held.
Old May 13, 2004 | 04:56 PM
zooker's Avatar
thanks for the diagram. you say it is in the center of the end panel. which end panel where is the relay located in the car. someone also suggested that there may be an inline fuse. any possibility?
Old May 13, 2004 | 05:08 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello Zooker,
Welcome to the board. The end panel would be the trim panel going across the back of the trunk or cargo area. The release relay is in the center console behind the shifter assembly. The in-line fuse you have heard talk about is on the t/a, firebird, & gta's. It takes the place of the "lid" fuse in camaro's and is located in the wire bundle at the fuse panel, sometimes a pain to find. It is a red/white wire with the in-line fuse in it.
Old May 13, 2004 | 08:33 PM
Speedgraphic's Avatar
Car: '90 RS Vert
Engine: 305 TBI
Transmission: 700-R4
The switch you are looking for is in the trunk. It is a part of the trunk closer mechanism. If you remove the trim panel at the back of the trunk and look at the trunk lid closer toward the bottom on the left side you should see where a wire should be plugged in. Probably a loose connection, but it could be that the switch is bad or needs adjustment (positioning). I would check the connection. If that did not help you might short the two wires together with a piece of wire - this would simulate the closed position on the switch. If the Solenoids fire then the problem is with the limiting switch and not just a loose connection
Good Luck!
Speedy
Old May 23, 2004 | 02:52 PM
zooker's Avatar
thank to all who helped
removed the end panel and sure as heck the connector had come undone from the deck switch. Plugged it back in and it works fine. Thanks again for all your help.
Old May 25, 2004 | 07:54 AM
Car: '90 RS Vert
Engine: 305 TBI
Zooker,
Isn't is sweet when it works!
When I got my car the switch did not work. I was having to raise the back of the top and while holding it up climb in and lean the seat forward so I could get to the loops and pull them both at the same time so the tonneau would clear.
When I found the loose wire and electrically popped the tonneau the first time it was almost as good as good as it gets!
Happy (topless) Trails!
Speedy
BRoss99
Aug 10, 2025 05:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
stalkier
Aug 21, 2015 01:54 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
