So if our middle button releases the top
Old Jun 19, 2004 | 03:22 AM
Ovrclck350's Avatar
What releases the power trunk pulldown?
I've finally figured out why it never powered on (fuse) and why the fuse was out, but was wondering if ours ever came with a switch to release it like on the other thirdgen's.
If not, is it relatively easy to wire in? I'll have a trunk button after my 4th gen dash swap, so I could use that button for it.
Old Jun 19, 2004 | 04:19 AM
RicksRedNomad's Avatar
Car: Several
Engine: Several
Transmission: several
As far as i"ve been able to understand this, The Camaro had no provision for this, Maybe some of the Pontiac's did!!!!!!
Here are a couple of thread's with info concerning your question, The first link seem's to answer your question best................
Hope this help's and Good Luck!!!!!!!!!!!!
First
Second
Old Jun 19, 2004 | 05:30 AM
Ovrclck350's Avatar
I read those links, but it was talking about release only hatch units (from what I gather). Mine is a power pulldown, but I was just curious if there's no release button.
I'll go look at it and get pics when I get a chance.
Old Jun 20, 2004 | 11:26 PM
Guest
Guest
Posts: n/a
On mine, they used the hatch release switch (and solenoid I'm pretty sure) for the tonneau release.
Old Jul 4, 2004 | 01:54 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Correct. ASC used the hatch release wiring and relay for the tonneau release. But there is nothing preventing you from adding a trunk solenoid release, switch and relay yourself (as I did). I got a trunk release from a 80's Caprice. The switch was located in the glove compartment. I put the switch in my center console. The trunk release solenoid is simple to install, just one 10mm screw attaches it where the standard manual release goes. There is just one hot wire running from the relay to the solenoid. Don't forget to add the roughly 10" grounding wire from the 10mm screw to the grounding location on the body just below the trunk pull-down unit. The solenoid is isolated from ground by the guides in the pull-down channels.
Lon
Old Jul 15, 2004 | 12:18 PM
badjuju342's Avatar
Car: '89 rs convertible
Engine: ls1
Axle/Gears: 3.73 posi
very important to remember thingy: do not pop trunk and release tonneau cover at the same time unless you like gouges in your paint , almost nailed mine but good .
Old Jul 15, 2004 | 12:43 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i also did the same thing lonsal did.
first i moved my tonneau cover switch to the cover itself.. like the 92s had... its alot more convenient
on your trunk latch, when you turn the key, the key just pulls on a cable.
this cable loops around to the latch.. when the latch is released, it triggers the power pulldown. if your struts are weak, and were to leave the trunk on the latch, when the power latch got to the top, it would just click and pull it back down.
the electric release is exactly like the cable release.. it actually connects to the lock and has the cable... but on the latch where the cable pulls it, theres also a solenoid... this 'noid pulls just like if the cable did it.
so all you have to do is give the solenoid power using a relay.
Old Jul 26, 2004 | 01:52 PM
drop-top IROC's Avatar
Engine: 305 TPI (LB9)
Transmission: WC T-5
Which is likely the reason that both a trunk release and a tonneau release were not installed at the factory.
theshackle
Aug 31, 2015 10:47 AM
5spdcamaro
Aug 28, 2015 02:12 AM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
smooth
Aug 18, 2015 06:34 PM
