my 89 irocz convert
Car: 1989 irocz convert
Engine: 383 tpi
Transmission: 4 spd auto
my 89 irocz convert
A couple of members say this can't be a real iroc z?? Is it possible it is an 88?? Just wondering
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
look at your rpo codes which will be on a sticker on the inside of your arm rest. The RPO code for IROC is B4Z. If it has B4Z, it's an IROC, if it doesn't, You don't....pretty simple
Car: 1990 Iroc Z Convertible
Engine: LB9
WRONG! In 1988 GM in its ultimate wisdom did away with the Z28 and made the IROC Z a standalone model. SO your '88 will not have RPO B4Z because essentially if it wasn't a base model Lt or RS(or whatever designation the lower models got) you have an IROC Z. Look throught your RPO's I believe rpo Z28 will be there as it was a suspension type rpo, also if you got the 16" rims and 245 series tires that is also a clear indicator.Hope htis helps.
Car: 1987 Z28 Convertible
Transmission: 5-speed
Zedder is correct. RPO B4Z was only used in 1985 - 1987, when the IROC-Z package was an option on the Z28. The IROC-Z became the base sport model in 1988 but RPO B4Z was not used. Ironically, RPO Z28 was used on IROC-Z from 1988 thru 1990. Go figure...
It is true that the 16-inch wheel was exclusive to the 1988 - 1990 IROC-Z and a car that's equipped with them is proof that it is an IROC-Z. Look inside the driver's door jamb for the tire decal. It will list the original tire size. Although this information is good, having a suspected IROC-Z with 15-inchers does not rule it out as a true IROC-Z. That's because 15-inchers were made the standard rim size on 1988 IROC-Zs and the 16-inch wheel was an option.
Engine: 383 tpi
Thanks Zedder---yes i do have the 16 inch rims with the 245 tires.
Thanks for all the info---you guys really know your third gen info!!
