convertible top hardware needed
Old May 19, 2005 | 02:19 PM
cuda69's Avatar
Car: 91z28vert,3:42posi-rear,gu6
Engine: 305TPI
Transmission: T-5,pro5.0 shifter
anyone out there have any hardware for a 1991 z28 convertible need fastener that holds release lever against the underside of tonneau,this is also fastener that holds rear bow pin until released again when you pull on lever,also if someone could please post a photo of a complete release lever the one on the underside of the tonneau maybe i can get a new fastener made from a pic of one,i would really appreciate a pic of the latch fastener for 1991 z28 convertible thanks a lot send pic to jamescuda@yahoo.com
Old May 19, 2005 | 05:03 PM
weigesco's Avatar
Car: 89 RS Convertible
Engine: 350 Carbed, No Computer
If it is like my 89 then you should be able to use a pin like you would use for a trailer hitch or a hood pin. If you do a search on here I know that somebody drew a very good picture of the latch assembly.
Old May 19, 2005 | 07:11 PM
cuda69's Avatar
Engine: 305TPI
thank you,but iam not having any luck locating any diagrams,any help would be welcomed thank you,the idea about the trailer latch wont work has to be an open jaw slide on with little to no resistance,tried everything,must be exact match 1991 convertible tonneau latch assembly. thanks ill hope for help
Old May 19, 2005 | 08:11 PM
weigesco's Avatar
Try these 2 pages and see if that is what you need.
https://www.thirdgen.org/techbb2/sho...onvertible+top
1992 Trans Am
May 10, 2023 07:19 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
