middle light
Old Sep 23, 2005 | 01:28 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
middle light
i guess this would be a convertible question b/c of the way the middle tail light is set up on our cars...but for some reason i can't figure out why my middle light WONT WORK...the bulbs aren't burnt out, i unhooked and rehooked the light assembly to the wire that runs thru the spoiler, i even detatched the circtuit that touches those lil' metal pads to the wire running from the light assembly, and made sure the coil was touching the metal sitting by the trunk latch...can't figure out why the lights aren't coming on...
any suggestions?
Old Sep 23, 2005 | 01:29 PM
BlueZee28's Avatar
and as far as i know there isn't an individual fuse for just the middle tail light is there?
i'm pretty sure there's only one for all the tail lights
Old Sep 26, 2005 | 09:33 PM
zedder 1 9 9 0's Avatar
Car: 1990 Iroc Z Convertible
Engine: LB9
I had the same problem, I took some fine sandpaper and sanded the contacts on the trunk lid and then sanded the contact patch on the trunk base and that did the trick. I guess dirt or corrosion had built up over the years and there wasn't enough metal to metal contact for the light to work.Works great now.
Old Sep 30, 2005 | 08:34 PM
Speedgraphic's Avatar
Car: '90 RS Vert
Engine: 305 TBI
Transmission: 700-R4
Third Light
Now that you mention it I haven't even looked at that light in a long time. I'm going to check it tomorrow!
Another thing I've been considdering is a change over to LED Tail Lights.
Speedy
Old Sep 30, 2005 | 08:46 PM
BlueZee28's Avatar
i'll have to try that thanks.
383cam
Sep 9, 2015 06:01 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
