Added trunk pop to my vert
Old Mar 9, 2008 | 03:24 PM
  #51
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Re: Added trunk pop to my vert
Originally Posted by allgood
what do i need to do this swap, i been told diff. things i have a 92 ta vert.
so do i need the whole unit from a non-vert or do i just need the electric popper from a non-vert unit. please help
Holy hell. It's been said so many times in this thread. Just read! There was ONE post saying something else that was quickly bunked. You need the whole assembly!
Originally Posted by shr00m
You need a motrized pull down unit from a 92 non-vert car and some wiring skills. You'll need a switch, a relay and be able to follow my instructions above. .
Originally Posted by iansane
Lon said that the 92 style didn't come with a non-pulldown and eletric popper version so you have to mount a pulldown motor and everything in there
Originally Posted by lonsal
For a 91-92 'vert you'd have to swap the entire pull-down unit from a late 91-92 coupe.
Old Mar 9, 2008 | 07:50 PM
  #52
Adrians91Z28's Avatar
Car: 91 Camaro Z28 Convt.
Engine: 305 TPI (built)
Transmission: 5 spd
Axle/Gears: 3.08 posi
AWSOME !!!
one more thing to put on the "to do" list ..
when i got some money lying around, im gonna get a viper alarm system and get the trunk and the windows hooked up ..
then i can walk up to the car, throw my school stuff in the trunk while rolling down the windows .. then two latches and the top is down ..
YIPPEEE for technology .. lol .. who ever said you need some cadilac ..
hahah ..
Old Mar 10, 2008 | 12:48 AM
  #53
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Just remember you have to close the trunk BEFORE opening the tonneau.
Lon
Old Mar 12, 2008 | 08:17 AM
  #54
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I wonder how difficult it would be to put a mercury switch on the trunk lid and the tonneau lid so that both could not be opened at the same time... Electrically....
John
Old Mar 12, 2008 | 10:56 AM
  #55
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
I've had the trunk popper for a few years now and haven't opened both at the same time yet. It just takes some common sense.
And how often do we stow the top at the same time as accessing the trunk area?
Fortunatelly, the trunk lid doesn't fly open when you pop it. It just stays down. So if you realize your mistake, nothing bad has happened yet.
It really is no biggie.
Lou
Old Mar 12, 2008 | 11:59 AM
  #56
Transmission: 5 spd
yea .. i dont think ill be multitasking when taking the top down .. or putting stuff in the trunk .. lol
but good point
Old May 7, 2008 | 08:43 PM
  #57
allgood's Avatar
Car: 92 WS6 Trans am convertible
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
Originally Posted by Speedy Mike
i finally got the motorized trunk release from a 92 firebird, it fits perfectly, anyone know how to wire it?
do you have any pics i got a pull down unit from a 92 camero with the tan colored piece
Old May 7, 2008 | 09:00 PM
  #58
allgood's Avatar
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
now what do i need to do to add power trunk to my 92 trans am convertible
Old May 7, 2008 | 09:15 PM
  #59
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Old May 8, 2008 | 02:04 PM
  #60
allgood's Avatar
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
funny, but i have been told different things
Old May 8, 2008 | 02:22 PM
  #61
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
https://www.thirdgen.org/forums/post...01-post51.html
Old Dec 24, 2010 | 12:56 AM
  #62
claytonjn's Avatar
Car: '92 Camaro Vert
Engine: 305 TBI V8
Ok, here's my situation. I have a 1992 Camaro Convertible. First thing I did after getting it was installed an alarm/remote start/keyless entry. I wanted to be able to open the trunk with the remote instead of having to flip the plate down and use the key because 1 it was scratching my plate frame, and 2 I like keeping the door key in my wallet so if somehow I lock the keys in the car I can still get in. Anyways, I bought one of the 91.5-92 pull-down latches with the tan casing, bolted it right in, did a little modifying of the electrical stuff (I have it set so that not only can it not be opened when the car isn't in park, but when the tonneau is open it will not open and vise versa. I also have it hooked up so the console switch only works when the key is in but the remote works any time). I also had to modify the mounting of the trunk lid struts a little bit - even though they were brand new the motor would still pull the trunk back closed, so I had to move where they attach inside the trunk down about 1" This has worked perfectly for the last 6 months.
Now I have a couple problems. 1-because it's a 92, my car has the molded carpet for the driver's and pass side. I think the plastic pieces look a lot cleaner and more refined, so I bought a couple of those to put in. Unfortunately with the struts mounting point moved down they will collide with the plastic pieces if I completely close the trunk. 2-I'm trying to install a locking shelf. Please don't try to convince me not to or whatever I have my reasons for wanting this. If you don't think it's a good idea, cool - like I said I have my reasons and I want to. Anyways, I got the shelf and the plastic latch trim that will accept the shelf, but they are both from a non-pull-down car. I have been unable to find one from a car with the pull-down latch. The hole on top that the latch moves up and down through I could easily make bigger, but it looks like it's definitely not deep enough for the pull-down latch. I have a few questions regarding this...I know they made this trim piece stick out more for pull-down equipped cars, but is the 91.5-92 pull-down latch more low profile and would fit? (probably wishful thinking) Will the 91.5-92 slam down latch the car came with originally even fit in there? Is there ANY way to make the 91.5-92 slam-down one power operated?
If I could make the 91.5-92 slam down latch power it would solve all my problems...I'd be able to relocate the trunk lid struts to their original mounting locations to they would clear the plastic trim, and I could use the shelf and trim I already have. It seams like I should be able to get any solenoid to pull the cable to unlatch it, although it'd be really cool to get the solenoid referred to earlier to bolt right in it looks like someone tried that and was unsuccessful. I know the other option would be to attach the older style slam latch, but I guess that requires more than drilling new holes - taking the whole mounting plate from another car and welding it to mine, is that correct?
Any tips, advice, etc would be greatly appreciated!
RS Reaper
Oct 17, 2018 07:52 PM
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
okfoz
Oct 13, 2015 02:19 PM
gord327
Oct 3, 2015 01:25 PM
Luigytico09
Oct 1, 2015 08:46 AM
