convertible seat belt help
Subscribe
Apr 16, 2006 | 05:18 PM
I was wondering if the seat belts on an 87 camaro convertible are the same as the coupe or t-top models? if so does anyone have a set for me I want either light saddle (preferrable) or black. Thanks
Reply 0
Apr 17, 2006 | 10:49 PM
they are not interchangeable........
Reply 0
Apr 21, 2006 | 05:02 PM
anyone know where to get some black ones then because I doubt I can find a set in light saddle. it was only used 85-87. or anyone know if they can be rebuilt and the webbing dyed and where to get the stuff to rebuild and the correct color dye?
Reply 0
Apr 22, 2006 | 11:21 PM
try hawks third gen they have some. Atleast they did.
Reply 0
Apr 22, 2006 | 11:49 PM
Quote: they are not interchangeable........
They aren't? I always thought they looked real similar. Just mounted in a different spot....
Reply 0
Apr 23, 2006 | 10:27 AM
I think the rears are the same on mine as the coupes but I don't think the front ones are the same.
Reply 0
Apr 29, 2006 | 04:30 PM
I don't know how much this will help you, but http://www.Ssnake-oyl.com can most likely at least re-web your belts.
Reply 0
Apr 29, 2006 | 04:34 PM
I saw that but price was pretty high if I was looking at the right thing. $190 per belt.
Reply 0
Apr 29, 2006 | 04:55 PM
The front ones should be the same, but the back ones are different for sure.
Reply 0
Apr 29, 2006 | 06:57 PM
John,
For 1987, the front convertible belts are different from the coupe's belts. It's the shoulder retractor that's a completely different design. They are not interchangeable. As for the rear belts, they are identical. When I changed interior color on my '87, I found a parts car (coupe) and all the belts worked on my convertible except for the two front halves with retractors. For these, I bought them new from GM -- this was around 1995 so they were readily available. Today, this is not the case.
Reply 0
Apr 29, 2006 | 07:37 PM
do you know if the front ones can be taken apart and rebuilt and merged with a set of black ones? I am keeping the interior in mine light saddle but I can't find any light saddle seat belts in good enough shape to buy so I guess black will look alright.
Reply 0
Subscribe
