Vert 6x9 Panels
Old May 2, 2006 | 08:43 AM
serpentineocean's Avatar
Car: 1986 Vert Z28
Engine: SuperCharged 350
Transmission: 5 Speed Manual
Vert 6x9 Panels
Hey guys, I am working to build a functional panel(s) to hold a 6x9 in the rear sail panel. I was wondering, if anyone else is interested, I was thinking about making a mold, so i could just fiber-glass up copies if it works out well. Mabey sell them a little above cost if people wanted them.
*shrug* just a thought.
Old May 2, 2006 | 12:36 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Are you talking about 6x9 speakers?
Old May 2, 2006 | 05:11 PM
gray89vert's Avatar
Car: 1989 RS convertible
Engine: 305 TBI LO3
Transmission: TH-700-R4
Axle/Gears: stock axles 3.73 LSD
why make a molding when all you have to do is cut a big hole in the old ones
Old May 2, 2006 | 10:55 PM
WillSpeedy's Avatar
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
because this is what's behind that panel. About 5" of the 6-1/2" factory speaker. Cause there is so much metal behind it they couldn't do it properly.
Old May 3, 2006 | 05:51 AM
Car: 1986 Vert Z28
Thanx! lol.
Old May 3, 2006 | 10:52 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Yes, there is extra bracing behind the speakers. So you will need to grind it down or relocate the speaker a little.
However, you won't be able to use common 6x9's because they are too deep. They won't fit. How I know? Because the previous owner had 6x9's in cutout holes ... attached with 3" drywall screws and they were sticking out an inch at least!!
Lou
Old May 3, 2006 | 11:22 AM
Car: 1986 Vert Z28
Hence, i'm not re-locating them, i'm either building a whole new panel, or i'm going to add a 2.5" (flush to that lil armrest) box to extend it out. So you can fit a bigger speaker, and hopefully have it in a enclosed box. = a lot better sound
My only issue i'm lookin into is giving the seat release handle space to fold down. I don't think it's a big issue for me, but if people wanted to buy these id think they'd still like to put there seats down if necessary.
Old May 16, 2006 | 10:07 AM
91 VANE Z's Avatar
Car: 91 Z28 Convertible
6x9 area
I installed 6x9's on my vert. I added a 2 inch spacer made out of wood, it is actually two pieces glued together to give that tappered look so that the top of the spacer is only the size of the 6x9 and the bottom is slightly wider.
covered it in leather to match the rest of the panel and it looks part of the car. my seats fold down without touching the speaker.
I will take some pics and post it.
Old May 16, 2006 | 10:37 AM
C6matt's Avatar
Car: 05 C6, 91 z28 Vert, 66 Mustang vert
Engine: Ls2, TPI 350, 289 4bbl
Transmission: T-56, T-5, C4
Axle/Gears: 3.42,3.08,3.73
I would be intrested, the previous owner hacked mine up...
Old May 20, 2006 | 09:24 PM
GMZombie's Avatar
Car: 89 Camaro RS Convertible
Engine: 355 chevy power
Transmission: 5 speed manual
Axle/Gears: standard
i too would also be interested as right now i have 5x7" in right now but would like 6x9's...
Old May 21, 2006 | 09:46 AM
Car: 1986 Vert Z28
well, here is a quick wooden rough draft. I needed something to get me to MD, i plan on re-doing in fiberglass, mainly because the wood is just too heavy.
Old May 21, 2006 | 10:15 AM
Hylton's Avatar
Car: A Camaro of some sort.
Car audio stores usually have the one one and two inch spacers available in black plastic. Pretty cheap and gets the job done.
Old May 30, 2006 | 07:14 PM
mrws6speed's Avatar
Car: '02 WS6 Conv M6, 92 WS6 Conv. M6
That's a really sweet setup.......
Old Jun 9, 2006 | 10:22 AM
91 VANE Z's Avatar
Got some pics, here they are.
Attached Thumbnails Vert 6x9 Panels-p1000772.jpg   Vert 6x9 Panels-p1000775.jpg   Vert 6x9 Panels-p1000777.jpg
Old Jun 9, 2006 | 02:46 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
What is the original size of the OEM speaker?
4X6?
Old Jun 13, 2006 | 12:07 PM
C6matt's Avatar
did you make them yourself?
Old Jun 16, 2006 | 02:42 PM
penji04's Avatar
That looks great ill have to do something like that with my vert.
Old Jun 18, 2006 | 09:33 PM
dual_88s's Avatar
From: In my own little world - but they know me well in here
Car: 88 Sport convertible
Engine: 305TBI
Transmission: AUTO
Axle/Gears: 3.42 rear end
Original speakers were 6"
I had 6x9's and hit the problem of the bracing being in the way, did the 'trim' the bracing, a little extension, but found my BEST results going with a set of 6 1/2" Infinity's...better sound than 3 different sets of 6x9, and NO issues with fit.....
Old Jun 19, 2006 | 11:41 AM
OneBadZ4U's Avatar
Car: '86 Iroc, '87 Iroc Vert
Engine: 350 TPI, 305 TPI
Transmission: T5 in both
Axle/Gears: 3.73, 3.45 both LSD's
They look pretty good serpentineocean. Not sure if I'll do it but, will see.
OneBadZ4U
Old Jun 21, 2006 | 02:35 PM
jagevileye21's Avatar
Car: 1991 Z28 Vert
Engine: LT1 350
Transmission: T56 6 Speed
Do you guys think that 1-1/2" spacers will work and give us enough room to mount some 6x9's?
Jay
Old Jun 22, 2006 | 08:18 AM
Car: 1986 Vert Z28
Jay
I don't have my notes in front of me, but i believe that's all mine are (speakers are actually sunken in so you can't damage them)... but really it depends upon the depth of the speaker. They are all different.
Old Jun 22, 2006 | 10:54 AM
Car: 1991 Z28 Vert
Engine: LT1 350
Serpentine,
What is the mounting depth of your 6x9's? Also, when you get a chance could you check and see what size spacers you are using?
Thanks,
Jay
Old Jun 22, 2006 | 11:37 AM
Car: 1986 Vert Z28
Serpentine,
What is the mouting depth of your 6x9's? Also, when you get a chance could you check and see what size spacers you are using?
Thanks,
Jay
I am not pulling my speakers again, but i think they were 4" total depth. 3-3/4" bottom depth. its complicated to explain, so i made a lil model of it. ... mabey somone can verify the dimension, cuz that was best guess off the top of my head (camaro isn't available to me right now.. lol.)
yea, it's deff not 1'-6" across... *shrug*
Last edited by serpentineocean; Jun 22, 2006 at 11:40 AM. Reason: Automerged Doublepost
Old Jun 26, 2006 | 09:38 PM
91 VANE Z's Avatar
Yes. It's only MDF cut in two different sizes. One larger than the other one, then glued together. As son as you out some type of fabric over it, it gives you that tappered look.
okfoz
Oct 13, 2015 02:19 PM
kkirch15
Sep 30, 2015 04:44 PM
FormulaEngland
Sep 30, 2015 01:50 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
formula00ra
Sep 28, 2015 11:50 AM
