can`t get top down
Old Mar 10, 2007 | 03:58 PM
jaysfs's Avatar
Car: 91 z28, 07 trailblazer ss
Engine: lt1lt4 hot cam,ls2
Transmission: t56
can`t get top down
I am a new vert owner and i can`t get cover to open up. It has power at the switch and makes a click sound under the switch put the lid won`t open up. sucks,it`s the best out it`s been in months here
Old Mar 10, 2007 | 06:11 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
You have manual releases back behind the back seats. Theres a cord coming off each solinoid that pop the levers. Dig around you will find em back there.
Old Mar 10, 2007 | 06:55 PM
Droptop_Z's Avatar
Car: 88z
Transmission: t-5
Try pressing down on the drivers side tonneau cover while pressing the switch on the console. I don't know whats up with my 91 but that is the only way it will open without using those strings behind the rear seats.
Old Mar 10, 2007 | 07:46 PM
jaysfs's Avatar
Transmission: t56
okay i can get the top to lift up from the lid by pulling the cable. i will searchout the cable 2 the soinoids
Old Mar 10, 2007 | 08:01 PM
87_Injected's Avatar
Car: 2010 2LT RS
Old Mar 11, 2007 | 07:21 AM
Speedgraphic's Avatar
Car: '90 RS Vert
Engine: 305 TBI
Transmission: 700-R4
The manual releases sometimes get hidden. They are attached to the latch and at least on mine are small plastic covered cables with a loop in the end.
If you have power and you can hear something clunking in the solenoid area you it sounds like most of the circuit is working. You might have power to one solenoid but not both... That's what I would check after you get your tonneau to lift by using the manual release.
When I got my car the electric release would now work. I had the car for about a year before I was finally able to find the problem. The manual release is a PITA but you can live with it until you get the problem sorted out.
Good Luck
Speedy
Old Mar 11, 2007 | 07:28 AM
Car: '90 RS Vert
Engine: 305 TBI
Old Mar 11, 2007 | 03:31 PM
jaysfs's Avatar
Transmission: t56
thanks everyone, and speedgraphic i found those imiediatly. And its the first time with the top down with me.
Old Mar 11, 2007 | 06:05 PM
Car: '90 RS Vert
Engine: 305 TBI
S W E E T!!!!!!!!!!!!!!!!!
How was the weather?
We don't get a lot of cold weather in South Georgia so I can pretty much go topless at least a bit most all year. Wearing a jacket and with the heater on I have been out near freezing cruising around town...
I hope you had a good ride in yours when you finally got the top down.
When you get ready to figure out the electric relase post here or Email me. I've been through mine from one end to the other!
Speedy
"It's hard to slow down when you were born to run!"
Old Mar 11, 2007 | 06:19 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Sometimes it's not even that. It could be that the latches are just stuck and need some WD-40. My cover doesn't open up sometimes when I hit the button, and then other times it does. It's just the latches getting hung up. Kinda a hit and miss with mine.
Old Mar 11, 2007 | 07:47 PM
WillSpeedy's Avatar
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
Yea most of the time mine will only open while press the tonneau cover down and press the switch at the same time. I am shocked when it occasionally pops without pushing. I took mine for a cruise last week when it was +10 celcius(50F). The highways are dry but the city is sloppy.
Crank the heater crank the tunes and it's all good.
Old Mar 12, 2007 | 12:05 AM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Congrats and enjoy.
There's still a foot of snow on the ground here.
Old Mar 12, 2007 | 09:04 AM
jaysfs's Avatar
Transmission: t56
thanks and yea i enjoyed it.But can`t wait too get my Z done with motor work now. it`s in the 60`s here right now and no snow on the ground
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
Nick McCardle
Sep 10, 2015 08:36 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
rsrookie
Sep 5, 2015 07:08 PM
