GM stock convertible subframe connectors??
Old Apr 17, 2007 | 02:53 PM
91CamaroRS305's Avatar
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
I ran into a guy that had a ttop car and SFC, when I asked him what brand they are he said he went to a GM dealer and ordered them for a same year convertible Camaro. My question to the vert board surfers is (yes I searched) are the GM SFC out there and will they stiffen up a har top car??
Thanks ahead of time.
Old Apr 17, 2007 | 03:37 PM
Guest
Guest
Posts: n/a
Re: GM stock convertible subframe connectors??
I dont know that they are/were available separately from GM but even if they are I wouldnt bother. Just get some aftermarket ones from Spohn, UMI, Alston, whatever.
Old Apr 17, 2007 | 03:42 PM
DJCobol's Avatar
Car: '89 Black IROC 'vert
Transmission: 700-R4
Axle/Gears: 2.73 posi
GM didn't have SFCs to my knowledge. Only thing that ASC did was to box the rocker area in.
Old Apr 17, 2007 | 04:08 PM
Stephen's Avatar
Car: 87 GTA
UMI, Spohn, etc, run $200, so save yourself $150, and build your own for $50 max.
I'm tired of seeing aftermarket companies charge WAY more than the material costs. Hell, research costs are almost nil now. Easy to buy a set, copy them, tweak them as "your" design, and bingo, your done.
Old Apr 17, 2007 | 04:19 PM
jetblast's Avatar
Car: 91 z28 convertible
Transmission: 5 speed
Hey Stephen did you do your own SFC s on a vert?
Old Apr 17, 2007 | 04:23 PM
Stephen's Avatar
Car: 87 GTA
No, a buddy of mine did his own, on his vert.
Old Apr 17, 2007 | 04:33 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Since all 3rd gens began life as a T-top cars and ASC mounted the SFC to the bottom and chopped the top off, and GM had to sell parts, I do not see why GM would not sell them over the counter...
John
Old Apr 17, 2007 | 05:07 PM
jer4251's Avatar
Car: They all sit.
Engine: LS1, LB9, LB9, L98, LT1, LT4, LT4
Transmission: A4, T5, T5, A4, A4, T56, TR6060
if they did sell them, it would require people to chop their front fenders like they did on the verts. its a pain in the butt swapping fenders, having to cut and weld them.
Old Apr 17, 2007 | 05:24 PM
Stephen's Avatar
Car: 87 GTA
What was different about the front fenders? I thought only the rears were cut?
Old Apr 17, 2007 | 05:54 PM
Wheres a good place to get a "design" to tweak? I have thought about this myself and was a bit leary on it, I custom fabbed a trans crossmember for a th350/400 trans with torque arm mount, so SFC are something I would do to. I just want a pair I can copy
And what does everyone suggest, tubular or box steel???
Old Apr 17, 2007 | 05:57 PM
jer4251's Avatar
Car: They all sit.
their is about 6 inches or so removed from the fenders to fit the frame rails. and a special bracket bolts the fender to the body cause the orig mounting holes are gone.
Old Apr 17, 2007 | 06:08 PM
Stephen's Avatar
Car: 87 GTA
I'll go square, just because I'd rather stitch weld the whole length, rather than just the ends.
Old Apr 18, 2007 | 06:59 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I just put a new fender on my car. It was approx 3.75" cut off. It was right underneith one of the push in tabs for the plastic fender liner. I had to fab up 2 brackets to hold the bottom of the fender in place.
Old May 1, 2007 | 07:27 AM
nicksL98's Avatar
Convertibles had a rocker box and alos had reinforcments on the inside running from the cowl, along the rocker, and back to the B pillar. Sure you could probably get them from GM a while ago, but now that is highly unlikely.
jaridjohn
Jul 8, 2024 03:49 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
TheJoeY88
Dec 31, 2016 07:30 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
86White_T/A305
Aug 17, 2015 12:16 AM
