Rear Control Arm Bolts
Old May 16, 2007 | 08:38 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Although I have not looked, and it might be obvious once I get down there... How do you remove the rear control arms that attach to the axel... The axel side is easy, but the body side with the SFC I cannot forsee as being an easy job...
John
Old May 16, 2007 | 10:08 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Re: Rear Control Arm Bolts
ASC cut/tourched holes in there SFC's. The head of the bolt slides back into it, tilt the bolt, and pull it down and "back in".
I could not get ANY of my ratchets onto either end. Wrench city it was for me.
Old May 16, 2007 | 01:07 PM
okfoz's Avatar
That is what I was afraid of
I guess that would rule out the ole impact gun
John
Old May 16, 2007 | 02:06 PM
Dale's Avatar
Engine: 350 S-TPI
10-4
Old May 19, 2007 | 10:52 PM
DJCobol's Avatar
Car: '89 Black IROC 'vert
Transmission: 700-R4
Axle/Gears: 2.73 posi
Its actually pretty easy to get them out. I needed a small breaker bar to get them loose, but after that they came out with no problem. I the bolts soak in PB blaster overnight and then wire wheeled them before reinstalling.
Old May 25, 2007 | 11:10 AM
Speedgraphic's Avatar
Car: '90 RS Vert
Engine: 305 TBI
I did this with very little trouble... I used a breaker bar with about a 20" cheater. Worked like a charm.
Speedy
Old Jun 3, 2007 | 02:05 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Ratcheting open ends work really well in this app. If I remember right they are 18mm
1992rs/ss
Jan 31, 2025 05:10 PM
hectre13
Dec 11, 2023 08:14 AM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
