wanted: Latch slide plate for Convertible
Old Sep 30, 2007 | 07:13 PM
rlapenna's Avatar
Car: 1988 Iroc Z Convertible
Engine: 5.0 TPI LB9
Transmission: 5 Speed
Axle/Gears: 3.08
top. this is the rod system, not the cable system. i am looking for the slide plate that screws into the tonneau right behind the drivers seat. mine is gone. i have all the linkagem, just missing the slide. car is an 88 iroc.
Old Sep 30, 2007 | 09:43 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: wanted: Latch slide plate for Convertible
You have three options. No new parts exist.
Option 1: Try to find the parts you need from another early wrecked 'vert.
Option 2: Fabricate the parts you need.
Option 3: Convert it to the newer cable style tonneay latch pin release. Those parts are still available.
Lon
Old Oct 1, 2007 | 07:12 PM
dukie's Avatar
Lon
I am looking for the same..How would you convert it and where would you find the parts..??
Old Oct 1, 2007 | 10:11 PM
galletti's Avatar
Car: 1988 IROC Convertible
Hawks Third Gen Parts has a conversion kit that looks pretty good but is also pretty pricey. You can convert it yourself by drilling a lower hole on the pin holder and installing the cable system. Problem is the hole on your tonneau cover is still larger that the newer style release mechanism. A pretty simple plate will take care of that, however. I wanted to keep my vert very original but I had to look for the part for literally three years and when I finally found it it was $163.00 on ebay. VERY RARE PART!!! As someone who's been there, unless you need or want to keep your car original, here's the link:
http://www.hawksthirdgenparts.com/in...PROD&ProdID=16
Old Oct 3, 2007 | 08:03 PM
dukie's Avatar
Thanks for the link...I might have to go that way. But for now I will try to get original even if it is hard to find. If you come across one let me know.
Thanks, Dukie
Old Oct 13, 2007 | 07:46 AM
aldixie's Avatar
Car: 1991 RS Camaro Convertible
I think I saw one in my local pick a part. Was a couple of months ago. I did take some of the vert specific stuff for mine. I'm going over there today just to see what new 3rd gens they have in. I know they are normally pretty cheap there.
Alex
Old Oct 13, 2007 | 08:37 AM
rlapenna's Avatar
Engine: 5.0 TPI LB9
Axle/Gears: 3.08
that would be awesome. please let me know. thanks a lot!
Old Oct 14, 2007 | 03:39 PM
aldixie's Avatar
Hi,
Checked yesterday, the whole car has gone. Looks like the rest went to the crusher. Will keep looking for you.
Alex
Old Nov 24, 2007 | 08:41 PM
galletti's Avatar
Just saw this on eBay.
http://cgi.ebay.com/ebaymotors/88-Ca...spagenameZWDVW
Old Nov 25, 2007 | 06:55 AM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
theres a 88 vert in our pick/pull, I`m headed there this afternoon, I`ll take a look.
Hotrodboba400
Dec 10, 2019 07:07 PM
dbrochard
Oct 3, 2015 12:43 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Kenwood
Sep 4, 2015 05:50 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
