Question about 86 Convertibles
Old Jan 15, 2008 | 04:34 PM
mudjnky's Avatar
I'm considering a 86 Camaro convertible that I believe is an ASC conversion. Would the 87-92 convertible parts interchange with the 86?
Old Jan 18, 2008 | 02:23 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: Question about 86 Convertibles
87 and possibly 88 yes, 1989 they changed the top slightly and starting in 1990 they added a headliner, the 1989 tops are apparently the same. Most of the trim pieces I believe are the same however..
JOhn
Old Jan 19, 2008 | 11:24 AM
mudjnky's Avatar
Thnx!
Old Jan 21, 2008 | 08:02 AM
okfoz's Avatar
I should clarify, the 1989 & up are the same, the 1990 & up had the headliner. You will want an 86, 87 or 88 pieces. I think most of the trim pieces are the same however, just the tops are definately slightly changed.. Suposedly there is a 1/2" difference... not sure if the early ones are wider or the later ones are wider...
John
Old Jan 21, 2008 | 09:41 AM
Junior's Avatar
Car: 79 & 83 Camaro
John
Old Jan 21, 2008 | 12:28 PM
mudjnky's Avatar
Can the headliner be added to the earlier models?
Old Jan 21, 2008 | 12:37 PM
Junior's Avatar
Car: 79 & 83 Camaro
Yes.
Old Jan 21, 2008 | 12:43 PM
okfoz's Avatar
I would really be interested in how to add the headliner...
JOhn
Old Jan 22, 2008 | 09:08 AM
Junior's Avatar
Car: 79 & 83 Camaro
It install's the same way as the 86-up,you just have to take up both side's 1".Done it beforeto a couple of car's that did not come with a headliner.
The headliner attaches to the bow's with a plastic channel,or it screw's to the bow through a plastic strip,depend's on who you get the headliner from.
Old Jan 22, 2008 | 01:54 PM
okfoz's Avatar
So basically get the headliner and its pretty obvious?
John
Old Jan 23, 2008 | 08:58 AM
Junior's Avatar
Car: 79 & 83 Camaro
John
Yeap,it has been done too many times.And just a little FYI a headliner was a option in the 3rd gen vert's.
1992 Trans Am
May 10, 2023 07:19 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
