stock sfc
Old Feb 11, 2008 | 09:25 PM
topless89's Avatar
Car: 89 RS Convertible
Engine: 305 tbi
Transmission: 700R4,B&M friction,Transgo shiftkit
Axle/Gears: 2.73 LSD
stock sfc
done some searching in the threads... came up without an answer. has anyone tried stisch welding their stock sfc's? if so, did any good come of it?
Old Feb 12, 2008 | 01:20 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Re: stock sfc
I guess no one's ever tried it. I don't know why, it seems like it would be worth while. I'm thinking about doing this and putting in a couple of small bars (like spohns y-bars) from the ASC reinforcements, to the alston sfc's.
Does anyone know if you can see the front of the ASC stuff where if meets up with the firewall once you take off the fenders? Can you see the outer seam once you take off the rocker gfx? I would think that if you could weld the front up, along with stitch welding all the way down both sides it would make a HUGE difference. I'm just not that impressed with the Alstons alone, and am looking to improve the chassis without adding another set of sfc's or a cage.
Old Feb 13, 2008 | 12:09 AM
topless89's Avatar
Engine: 305 tbi
Re: stock sfc
looks like we're thinking along the same lines. i put on a set of alston's a while back and the handling inproved alot, but it still twists on eneven and bumpy roads. i'm not sere about the GFX, it looks like there's some adhesive holding mine on... should there be?
Jeremys87
Jul 14, 2022 09:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Genopsyde
Oct 7, 2015 08:35 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
