Sub-Frame connectors on a 1987 Z-28 Convertible
Car: 1992 Z-28 Convertible
Engine: 305 LB9 TPI
I am restoring a 1987 Z-28 Convertible. #11 of 13 that Willie has documented
. I want to install a set of sub-frame connectors. Do ya think this will be a deterrent for the car at a car show? I have a set on my 1992 Convertible and it's made all the difference in the world. I tried the bolt in on the 92, made things stiffer, but it still had flex issues. After I welded the sub-frame connectors, no more flex. So bolting the frame connectors in the 87 is not a option. Yes, I do want to drive the car as well as going to car shows.
So what to do ?
So what to do ?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Sub-Frame connectors on a 1987 Z-28 Convertible
you may loose points for the SFC,
if they are just local shows and you dont compete, then go for it.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
It would depend on the show, I know the TA nats they do not look under the car unless your tied for an award and they need to go deeper into your car than normal judging.
louishenry
Aug 28, 2015 09:41 AM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
Dialed_In
Aug 20, 2015 01:45 PM
