EFI Connection's 91 Trans Am Convertible Project
Old Jul 20, 2008 | 08:44 AM
S10Wildside's Avatar
I finally got around to putting the 91 T/A convertible project on the website. If you would like to follow the build, please bookmark http://www.eficonnection.com/eficonn...91TransAm.aspx. Updates (with images) will be available there. I'll also post some pics in this thread as they are available.
The car has been pretty much in a disassembly state, but we're now starting to put it back together.
Old Jul 21, 2008 | 01:46 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Re: EFI Connection's 91 Trans Am Convertible Project
That engine is the sexiest thing I've ever seen.
Old Jul 21, 2008 | 03:07 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I really like that coil-on-plug setup.. info ????
EDIT never mind I just looked at your web site.. very cool
Old Jul 21, 2008 | 03:33 PM
The coil per cylinder info can also be followed in the DFI and ECM forum. I can't seem to get the direct link to work without the URL being put into the browser twice creating a broken link.
It's a system we're prototyping at the moment. It works very well.
Old May 11, 2011 | 02:33 PM
mrws6speed's Avatar
Car: '02 WS6 Conv M6, 92 WS6 Conv. M6
I see the site, but I can't tell if the car ever got finished. Did it? Can you put up pictures?
Old May 11, 2011 | 07:41 PM
The car has been sitting collecting dust for the last two years. It may be 2012 before this car has priority. I've been considering using the Gen IV GM electronics and possibly a 6L80E/6L90E transmission.
Old May 11, 2011 | 08:55 PM
mrws6speed's Avatar
Glad to hear that the project hasn't completely stopped!
I've been strongly considered using your setup for my car.
What would be the benefit/difference of using a 58x vs. 24x?
Would it work with the rest of the factory gear like the gauges etc?
Old May 12, 2011 | 06:12 AM
24x gives you...
- cable or electronic throttle
- 4L60E, 4L80E, and T56 transmission support
58x gives you...
- electronic throttle only
- 4L60E, 4L80E, 6L80E, 6L90E, and T56 transmission support
- a higher learning curve to ECM tuning than the 24x
Gauges: yes all functional, but the tach will require a Dakota Digital interface
module
Etc: ???
Old May 12, 2011 | 06:29 AM
Twin_Turbo's Avatar
I read you're going to swap interiors, what did or are you gonna do with the cd player that's in there now??
Old May 12, 2011 | 07:43 AM
It was junk. Thrown out with the trash a few years ago.
Old May 13, 2011 | 04:09 PM
mrws6speed's Avatar
24x gives you...
58x gives you...
module
Etc: ???
Looks like I'll be going with the 24x system then
I already have the Dakota Digital interface because I have a T56 6-speed.
My "etc" was oil temp & pressure, fuel, and voltage. From your post the tach will also work.
I'm looking forward to the system!
Old May 13, 2011 | 08:20 PM
Those are based on sending units and are unrelated to swapping ECM/PCM.
Old Jul 19, 2012 | 07:51 PM
mrws6speed's Avatar
Have you made any progress on this project? I've seen the rebuilt TPI motor with your setup on eBay.
Old Jul 20, 2012 | 05:04 AM
No new progress on the car. I hope to begin working on the car next year.
1992 Trans Am
May 10, 2023 07:19 PM
camaro11j
Sep 19, 2018 08:49 AM
beachrodder
Aug 25, 2015 08:05 AM
1992 Trans Am
Aug 9, 2015 04:32 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
