Tonneau Question
Old Sep 11, 2008 | 01:04 AM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
Tonneau Question
I found an 88 at my local pick n pull.
Is there a way to release the latched from the tonneau with out power?
Old Sep 11, 2008 | 05:10 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Re: Tonneau Question
yes, just look for the cables behind the seat back. One on each side.
-jason
Old Sep 13, 2008 | 12:50 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Yep, there are emergency cable releases on each side just next to the latch bolt for the rear seat back. It is a black cable with a loop in the end. Tthe opposite end is attached directly to the tonneau latch. Remember these are supposed to be for emergency or limited use only. Some people use them regulary because their tonneau release button won't work. If you use them too much they'll eventually break and you'll be S.O.L.
Lon
Old Sep 13, 2008 | 04:11 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
I found them. And got the tonneau off.
I noticed that the end caps on the Camaro 89 are smaller then my Firebird 92. Is that normal?
Old Sep 14, 2008 | 03:15 AM
lonsal's Avatar
Yes. The Camaro is narrower than a Firebird. The trunk and tonneau are identicle on the convertibles, so the end caps need to be molded wider for a Firebird to cover the wider body.
Lon
Old Sep 15, 2008 | 08:01 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
The Firebird flared outward IIRC to give it a wider appearance I believe to match the Aero Spoiler of the Formula/Trans Am/GTA in 1991 & 1992...
John
Old Nov 25, 2008 | 06:46 PM
88GTAvert's Avatar
Lon
I have a question...I can't find the tonneau release button on my car (88 GTA), where should it be? I have only put the top down once so far and I used the emergency cables because I didn't see a release button! The only switch I found is the one that operates the motor to secure the 5th bow to the tonneau.
Old Nov 26, 2008 | 07:55 AM
okfoz's Avatar
It Should be the Trunk (Hatch) release button on the dash...
John
Old Nov 26, 2008 | 08:12 PM
88GTAvert's Avatar
John
Ohhh. I would have never thought of that. I know my car has the power trunk/hatch motor and I thought that button would just pop the trunk. I'll give that button a try this weekend!
Old Dec 13, 2008 | 08:56 PM
Wild Weasel's Avatar
Car: 1989 RS Drop-Top
Engine: 305 TBI
Lon
Been using the cables for a year now on my 89 rs vert. Where is this button and what does it activate to open the tonneau. The only button is on the console to open the trunk which does not work anymore. The motor and all the junk has been removed. So what opens the tonneau?
Old Dec 13, 2008 | 09:35 PM
lonsal's Avatar
On the convertibles the switch that releases the hatch was re-wired to release the tonneau.
Lon
Old Dec 16, 2008 | 05:14 AM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
The switch was also unique with regards to the graphics, which on the verts resembled the tonneau cover.
Old Dec 16, 2008 | 08:09 AM
okfoz's Avatar
That is the first time I have seen a switch like that one. I always thought the tonneau switches were the standard Hatch release/Trunk release switch.
John
Old Dec 16, 2008 | 12:02 PM
shibbykins's Avatar
Car: 91 RS Vert.
Engine: 350 TBI cammd
thts the first time ive seen the tonneau switch right on the center console, mines right next to the top release on the tonneau
Old Dec 16, 2008 | 12:38 PM
jeffwilly's Avatar
Car: 88 iroc convert
87,88,89 camaro's had them between the window switches with that tonneau picture on them. I don't know about the 90 and up?
Old Dec 16, 2008 | 12:58 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
90-92 had them right by the tonneau cover. some 87 's used the standard hatch switch 88 and 89 used the white print switch above. I think the later 87's may have used that switch also.
Old Dec 16, 2008 | 02:05 PM
evans87's Avatar
Car: 1987 Iroc Convertible
Engine: Bone Stock, 66,000
Transmission: 5 speed
That switch looks good. On my switch the the white print of the tonneau cover has worn off. Does anyone make a new one?
Old Dec 17, 2008 | 09:17 AM
91RSinNS's Avatar
Car: 1991 Camaro RS Convertible
Engine: 305 V8 TBI
Axle/Gears: 4.1
Wait...say wha...?
My '91 RS has that switch (complete with cooler looking Tonneau graphic) between my two power-window switches, not up on the tonneau itself.
Old Dec 17, 2008 | 09:39 AM
Engine: 305 TBI
Now ya got me going.... I have three switches on my 89 rs but they are not in line. If you move your tonneau switch back about the length of the window switches it will look like mine. Also no graphics left, course they are gone off the window switches as well. Are there any wiring diagrams for the tonneau and what do they activate to open the latches?
Old Dec 18, 2008 | 12:54 AM
Axle/Gears: 3.08
This topic has got'n interesting. I don't have any wiring diagrams, but I have a few pics of the tonneau cover latches that open to release it. You can also see the manual pull wire that can be used should the electrical solenoid activated release fail.
When the tonneau cover is in the down position, it locks-in with some tension. That tension allows it to pop up about an inch when the latches release. Otherwise, it would still just sit in the latches and you'd have to lift the tonneau cover while pressing the release button at the same time. That's kind'a awkward.
Old Dec 18, 2008 | 05:39 AM
NoCal91Convert's Avatar
Car: 1991 Z28 Convertible
Transmission: 5 Speed
My 91 z28 has the switch between the window switches on the console. I don't have a hatch release button. I didn't think most verts had one. The biggest problem I've seen is that the switch won't work if the trunk is not functioning correctly. Make sure the hatch pull down motor is all the way down. If not, it will not allow power to the tonneau release switch. In other words, if the connection is not made at the trunk (insuring the hatch is down) it will not allow the tonneau release button to work.
Old Dec 20, 2008 | 08:56 AM
Axle/Gears: 3.08
Right on. The when in the up (open) position, the tonneau cover and the trunk lid can not occupy the same space at the same time. It must be one or the other. Trying to do so would not be a good thing and could cause some nasty damage.
Old Dec 20, 2008 | 07:12 PM
Engine: 305 TBI
OK!! Now if I understand this right, power goes from the switch to the trunk lock down. If the trunk is down then power is applied to the tonneau . My trunk has no power lock down. (read delete) where is the wire that goes to the tonneau solonoids? Or does the switch provide a ground and the power is already at the solonoids? Is there a fuse that controls all this?
I have already rewired the 3rd brake light since it also goes thru the lock down system. Hence the brake light does not work with the trunk open...
Old Dec 30, 2008 | 05:57 PM
MYZ28NH's Avatar
Car: 91 Z28 Convertible
Wish this tread had continued as I am trying to get my release to work. need to know how this system is wired and where my problem could be.
1992 Trans Am
May 10, 2023 07:19 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
