Convertible conversion
Old Oct 4, 2008 | 08:40 PM
Dylan's Avatar
Ok i have a 91 rs just wondering if it would be possibe to turn it into a convertible. How much would it cost? Or is it not even possible? Any info would be great. Thanks.
Old Oct 4, 2008 | 10:03 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
Re: Convertible conversion
Its possible to change an RS in to a convertible.
Are you doing it yourself?
How deep are your pockets?
It may be LOT cheaper to buy one.
Good luck on your decision
Old Oct 4, 2008 | 10:18 PM
Stephen's Avatar
Car: 87 GTA
Not very long ago, a guy here on TGO did that. Turned hid hardtop into a vert.
Drilled out the factory spot welds, cut along the factory lines. And basically put it together, the same way the factory did, as if they were new parts.
Came out really nice & IIRC, wasn't NEAR as hard as anybody expected it would be.
Old Oct 5, 2008 | 04:28 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Yea..Didn't he have a hard top, then decided to make it a t-top car..then targa top..then cut off the whole thing??
Old Oct 5, 2008 | 05:20 PM
Stephen's Avatar
Car: 87 GTA
I'm thinking it was another guy, but could be wrong. Been awhile...
Old Oct 5, 2008 | 06:48 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
^ Chris (TPI383) did that very conversion, came out better than factory....
Old Oct 6, 2008 | 04:05 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I thought about getting a parts car and then trying to fab up a kit to do a conversion, or convert one of my Yellow Formulas... In reality there is a lot to it and not much to it at the same time... I would make the tonneau and the trunk out of fiberglass instead of Metal as it would be more doable. (Talk is Cheap)... I think ultimately the parts that everyone needs like the header trim pieces are the hardest pieces to get and would be the most difficult to fab together...
Ultimately I think if you found a wrecked vert, where you could salvage the parts and the car was not horribly bent it might not be a Horrible job, fabbing everything up (if you had to make everything) would be worse than finding parts and then modifying a car IMHO...
To be honest there are $3500 verts for sale everywhere, PERSONALLY I would go for something more rare than an RS vert as it will hold value better BUT your going to pay more up front...
John
Old Oct 6, 2008 | 11:25 PM
4ormula's Avatar
Car: 1989 Pontiac Formula 350(Maui Blue)
Engine: 355 TPI,accell superram,full roller
Transmission: Street/strip 700R4
Axle/Gears: Australian 9, 3:27 ratio
John, I was thinking exactly the same thing. You can find a vert cheaper than doing the conversion. Found my wifes 92 vert for less than $5k in Pennsylvania.
P.S congrats on the trophy at Trans Am Nationals. Nice to see the 3rd Gen formulas represented there this year.
Joe
Old Oct 7, 2008 | 07:53 AM
okfoz's Avatar
Back at you... Congtats on your runner up...
I saw that you drove through the Indy show, but I never actually noticed you parked anywhere...
John
Old Oct 8, 2008 | 12:00 AM
fazzt9101's Avatar
Car: 1984 Camaro z28/1991 Camaro RS
Engine: 383 Stroker in the z and a 305 rs
targa top sounds good wonder how hard that is
Old Oct 8, 2008 | 07:47 AM
okfoz's Avatar
Sawsall anyone?
Honestly you will have to reinforce the subframe to actually think of doing something like this, then cut the top...
I would not recommend it personally...
John
Old Nov 29, 2008 | 07:36 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
It was me who did it. T Top to targa top. Then targa to vert.
I had SFC's and a 8point cage.
was really easy. esp. since I used a totalled vert for all the parts needed.
search for the topic . there are a few posts about it.
If you cant find your answeres then Ask away and I'll answer what ya need.
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
LittleFranks
Oct 7, 2015 11:26 PM
m00n420
Sep 11, 2015 02:39 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
