ASC undercoating
Old Feb 13, 2009 | 12:32 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
ASC undercoating
I was wondering what other people have found on their ASC converted Firebirds & Camaros. I know that I have what appears to be a light black undercoating spray around the pieces and places that were converted or changed by ASC.
Do all ASC verts have this, or not?
Old Feb 13, 2009 | 12:45 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Re: ASC undercoating
I have never found any evidence of an undercoating or other surface prep, only some adhesive in a few places. Mine is a 91 built by ASC in March of 91. Where, specifcally, have you found undercoating on your 89? Knowing that, I will look again in these places.
Old Feb 13, 2009 | 01:38 PM
flippermtc's Avatar
Car: 88 IROC T-Top
Engine: 5.7
Transmission: Automatic
I just looked at a 1990 IROC and it didn't have any undercoating..
Old Feb 13, 2009 | 03:20 PM
okfoz's Avatar
Inside the rear quarter area mostly.
I know they flattened the top of the inner wheel well, so it may be from that.
John
Old Feb 13, 2009 | 08:21 PM
Dennis-Z28's Avatar
Car: 1991 Z28 Convertible
Transmission: 5-speed
Axle/Gears: 10 bolt, 3.08
I have it, all along the riveted area of the added sills too. Looks more like sprayed on glue but it is black and bumpy.
Old Feb 14, 2009 | 03:33 PM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
I also have it on my 92 Z28 vert, all along the factory subframe. Mine was made in May of '92
Old Feb 14, 2009 | 06:25 PM
JT's Avatar
JT
Community Administrator
Mine was built around the same time as Randy's, and I have it in the right rear quarter panel:
I also have it underneath, and that is what I really question:
You can see my panhard bars aren't completely covered, the muffler is partially covered and the end of the intermediate exhaust pipe near the muffler inlet is partially covered.
Mine is a 1992 Trans Am Convertible, by the way.
Old Feb 14, 2009 | 10:26 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
My car isn't a vert, but i have the same undercoating on my car. even on the door jams i got a little plastic piece that says something like "rust proofing", and when i pulled it out there is a hole about 3/8", shined a light in there and it looks like black undercoating. Also underneath my car it looks EXACTLY as JT's. my original exhaust was slightly sprayed, and even my driveshaft has undercoating overspray on it.
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
loud91rs
Oct 5, 2015 10:05 PM
Linson
Oct 1, 2015 05:33 PM
okfoz
Sep 15, 2015 05:22 PM
TRANSAM82-92
Interior Parts Wanted
Aug 15, 2015 01:26 PM
